Mowing What Size Bush Hog/Mower
   / What Size Bush Hog/Mower #1
miramadar
Eastern Kentucky
Kioti CK27
I have a CK27 gear. What's the best size rough cut and finish mower for a tractor this size?
   / What Size Bush Hog/Mower #2
A good rule of thumb is 1' of mower for every 5 hp, so I wouldn't go any bigger than a 5' deck w/ a CK27. Then again, Kioti offers a 6' mid-mount deck....
   / What Size Bush Hog/Mower #3
i did'nt think they offered any size deck other than a rear finish mower.
   / What Size Bush Hog/Mower #4
A 5' bush hog and a 6' finish mower is the major concensus.
   / What Size Bush Hog/Mower #6
2-3 PTO HP / ft for a finish mower.
4-5 PTO HP / ft for a rough cut mower.
We usually mount 72" rear finish mowers and 60" Rough cuts on the CK27 Tractors. Depending on the application requirements, they run these decks very well.
KIOTI doesn't have mid-mount mowers for the CK Series Tractors at this time. That may change.
   / What Size Bush Hog/Mower #7
I have no issues with my 5 footer but this really depends on what you are trying to cut and how fast you want to move. I can stall the mower at slow speeds if cutting heavy, wet, dense, head high grass. Usually I could handle an 8 footer while simply knocking the top 8" off of sparse, dry, field grass.
A 5 footer will be as wide as the machine and that's what you want to prevent catching a wide mower on trees and to prevent missing the grass that your wheels knock down.
I can't wait to start mowing.
   / What Size Bush Hog/Mower #8
Thanks - learn something new everyday.
Thanks for the replies! :thumbsup:
UNUSED FUTURE...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2016 Nissan Quest Van (A59231)
2016 Nissan Quest...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
