What size bush hog for TZ25???
   / What size bush hog for TZ25??? #1
wny770
WNY
Lots of old iron
What size rotary cutter would be best for about an acre of mostly tall grass and weeds?? Do you think a 5' would be too big for a TZ25da///19pto hp??? Thanks .
   / What size bush hog for TZ25??? #2
I think 4 ft. would probably be best, using 1 foot per 5 HP as a guideline.
   / What size bush hog for TZ25??? #3
I ran a 4' on my TC18 - it is as much the weight & size of the unit as HP required.
4' would be a good size for you TZ. Especially if it's only an acre. (figure about an hour job)
   / What size bush hog for TZ25??? #4
Welcome wny770!
Are you needing a rotary to cut the thick stuff only once? Will you be keeping up with the grass after the first cut? I would go with a 4'er. But if you intend on keeping it cut, maybe you could rent or borrow a rotary for the first cut then look into geting a finish mower. Or does your tz25 already have the mid mount mower?
Probably only once or twice a year. Mostly paths below the house. i think I'm leaning towards the 4'. I do have the MMM but I think the brush would just be too much. TSC has a king kutter for a little over 600. I think I just might buy...Thanks.
   / What size bush hog for TZ25??? #6
wny770:
Welcome to TBN :D! I agree with all the other posters as to RC size. I would "go" with KK- KK RC's appear to meet a lot of TBN member's needs. When I read about "paths" I start to think about ground clearances which is not a "strength" of MMM's especially when cutting less than level areas with "hidden surprises" :eek: Jay
   / What size bush hog for TZ25??? #7
To give you a sense of scale - here is a 4 footer on my TC18. The lovely model is my wife.
More pix here if you're interested Field mowing in Maine
Thanks for the pic...I'm going to get the four footer. TSC has the 4 footer (king kutter) for $609.98. I think for once or twice a year that would be fine. Thanks.....
HAZMAT, I ended up buying the woods BB48 as you have pictured. AWESOME piece, I'm totally satisfied. thanks for the pics.....You get what ya pay for.......:D
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
John Deere 6120E (A50323)
John Deere 6120E...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
