Mowing What size Bush Hog, 5' or 6'?!
   / What size Bush Hog, 5' or 6'?! #21
but the power steering is truly effortless with the 'hog attached.
Sean
You should try my Bushhog 306. (About 1100#) :laughing:
Without the loader on, I can lift the front end with one hand by grabbing the brush guard.
   / What size Bush Hog, 5' or 6'?! #22
I had the dealer ad 4 Kubota Weights on the front, so I hope it will have no steering problems with a HD 5' mower, even if I were to buy a second 6' mower later on. I plan to ad a Kubota FEL in a few months when I'm done saving up for it. I bought the biggest tractor my budget allow (wanted new not used), and decided to get the FEL added later when I could afford that without having to eat rice and beans for 2 years ;-)
I did same exact thing as you. Bought new tractor without FEL. About a year later, I bought a used FEL from Barlows for 1/2 price. Happy hunting. Philip.
   / What size Bush Hog, 5' or 6'?! #23
I have the same tractor that you do. I went with the 5' land pride bush hog and it does a great job with the tractor. It will try to stall in the heavy thick stuff just have o slow down a little bit.
   / What size Bush Hog, 5' or 6'?! #24
I did the same thing. I desperately needed to mow, so I got my B8200HSTD used with a rotary mower, but it did not have an FEL; it was what I could get for cash I had. I added a new loader a couple years later; was shocked at first that a loader for B8200/B2150/B2910 was over $3000. Since my tractor was already 12 years old, Kubota did not carry a frame kit for it; they would have had to modify one from a newer tractor. I went aftermarket, but still a bit over $3k...
It had three Kubota suitcase weights on it, till I got the loader.
Shame is there was a B2150, with FEL, Power Steering and 6 more HP right next to it that would have been perfect. But, I did not want to finance anything at the time. And, I did not know as much about tractors then. Although the B8200HSTD was a great tractor, in retrospect I wish I would have got the B2150...
   / What size Bush Hog, 5' or 6'?! #25
   / What size Bush Hog, 5' or 6'?! #26
The most commonly heard "rule of thumb" is 5 PTO HP/ft for rotary cutter width. I've been doing this for well over 40 years with numerous tractors and cutters and I believe this rule to be a minimum rather than an optimum. I would not even consider a 6' cutter for anything less than 35 PTO HP unless you plan to cut very light cover and/or slowly and/or often.
SDT
Listening and taking everyone's input into consideration, I wonder now if I should switch last minute from the L3200 to L3800. The deal/contract have yet to be finalized this coming week. Would it be worth upgrading to the bigger tractor? Besides $, why would I not want to upgrade? It appears to be 5.5hp more, worth the $2k jump?! I'm starting to question myself now, and 5 years from now, would I wish I went bigger now?! Pros and Cons?!
   / What size Bush Hog, 5' or 6'?! #28
I don't think you will regret the extra power.
   / What size Bush Hog, 5' or 6'?! #29
I wish I would have went bigger in HP originally. The larger "B" chassis was ok for my original intent. I sure wish I would have had more HP... I mean, in my case, the B2910 and the newer "B"'s have over 30HP; mine was same size, but 19hp.
For the current tractor, it is larger physically and HP than we were looking for; I was looking for a used L3410. They dried up in the local used market about the time I sold the B8200. The NH TC40D that we got, my wife loved the power the second she test drove it; I thought it was too big. She had been driving a L3410 at the nursery she worked at, loading compost and soil.
In this case, I love the jump to 40hp. But, this is a larger frame tractor than the L3410 too; it is physically big.
The Pros to more HP are easier to handle a mower or other PTO hp hog, maybe faster hydraulic cycle times. Cons? What Cons? Well, besides the $2k... :D
   / What size Bush Hog, 5' or 6'?! #30
I run a SQ 172 behind my L3400. Just for my private property use. Initial(first) cut went a little slow. Now that property's under control no problem. I went with 6' over 5 also because I have a JD235 mid-mount 48" decker. Also I tend to buy my attachments(includeing women :D) larger in case I get bigger tractor.
Boone
2012 Freightliner M2 106 Altec AM650 50ft. Bucket Truck (A55852)
2012 Freightliner...
2017 BIG TEX 20 AC 51' GOOSENECK (A57192)
2017 BIG TEX 20 AC...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
2006 iDrive...
Rooster Weathervane (A55853)
Rooster...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
148in Roll Up Garage Door (A55852)
148in Roll Up...
