Backhoe What size bucket to buy for a JD #7 backhoe
   / What size bucket to buy for a JD #7 backhoe #1
gordon21
Lake Lure NC
JD 790
I am considering buying a new 7 backhoe for my 790 tractor. There are several options on bucket sizes 9"-13"-16"-19". It will be used on the top of a mountain in western NC. Most rocks are beachball size or smaller with 4-12" of brown dirt/topsoil/thatch over a packed base of red dirt. It be used for general digging, tree planting, stump removal and limited trenching. I have reads posts where the 9" buckets tend to clump full and won't dump properly. I also don't want to buy too big
   / What size bucket to buy for a JD #7 backhoe #2
I found in my area that the 9" bucket was the best. I had other size buckets. But if I hit a root or decent size rock the bigger buckets had too much surface area and it didn't give me enough breakout force. I hope this helps.
Jim
   / What size bucket to buy for a JD #7 backhoe #3
I have the 16 inch bucket on my #7. It suits me just fine though I've not tried anything else. The 16 incher is pretty shallow so it takes the right sized bite of dirt for the little #7. If the narrower buckets are the same depth, it could take quite a while to move a lot of material.
Only once, when digging wet clay, did I have any problems with it not clearing fully. I suspect the narrower buckets would be more problematic. I will say, I have not done much stump work where narrower could be better. At the same time, I cannot imagine a wider bucket due to the limited power of the #7.
Hope this helps and good luck with your investment /forums/images/graemlins/smile.gif
   / What size bucket to buy for a JD #7 backhoe #4
Gordon:
I bought both the 9 & the 16. The theory being that the 9 will be fine for narrow/minimum disturbance trenching as well as the hard digging and the 16 would be available for the easy stuff or when I just needed to be able to move a larger volume faster.
BILL
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
2017 John Deere HPX Gator Utility Cart (A56857)
2017 John Deere...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
HUM V (A58214)
HUM V (A58214)
