Box Scraper What size box scraper for a Kubota L3010
   / What size box scraper for a Kubota L3010 #1
Grande
Southern Vermont
Kubota L3010HST
Greetings all,
I am about to purchase a box scraper for my L3010 HST. 32 engine horsepower, 25 at the PTO. The outside width of my R4 tires is 66". I'll be using it for hard packed dirt driveway maintenance; removal of humps and potholes, crowning, drainage etc. The terrain is not level.
The big question; will a 72" box scraper be too much for the tractor or would the slightly greater width be a benefit. Might a 66", the exact width of the tires be a better choice.
Thanks in advance for the advice.
   / What size box scraper for a Kubota L3010 #2
72" will be fine... you can always take it easy - not as much of a bite. I use a 6 footer, I like the extra width.
   / What size box scraper for a Kubota L3010 #3
We have used a six footer on our L3000DT,just take smaller bites if needed.I have used it on my L4240 and made work hard.
Thanks for the advice. The 6 foot it will be. If it labors too much I can always buy a bigger tractor!
   / What size box scraper for a Kubota L3010 #6
You probably know this already, but buy a blade with the clevis style hookup for the lower pins. Also get as much weight as you can afford.
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
2011 Peterbilt 365 Altec AC38-127S 127ft. 38 Ton Tri-Axle Telescopic Crane Truck (A55852)
2011 Peterbilt 365...
BED FROM 2024 FORD F250 SUPER DUTY (A57880)
BED FROM 2024 FORD...
