Front-End Loader What size bolts for attaching a loader to a Ford 1000?
   / What size bolts for attaching a loader to a Ford 1000? #1
4tractorsonthehill
ford 1000
I have a Ford 1000 and want to attach a loader. I need 4 bolts for either side on the transmission and need to know what size they are.
   / What size bolts for attaching a loader to a Ford 1000? #2
Welcome to TBN.
Are the holes cast into the transmission? If so call any NH dealer and they should be able to tell you what size they are. If they haven't been used, you should clean them out real good and run a bottoming tap into the holes. Mine on the 4000 were 3/4" and it took about 4 hours total to clean all 16 holes on the tractor.
Wedge
Thanks, but I found them this morning at the Ford Dealer. I made a template of the threads with a candle. The bolts on this tractor are actually 5/8". The tractor came with the house. Sometime before we got it looks like the battery leaked and etched the model and serial number plate beyond recognition, so I have trouble when I need parts. From what I can tell there were several versions of it. It is a good little tractor though and does what it was intended to do.
2017 John Deere 5090GN (A53317)
2017 John Deere...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Great Dane Van Trailer 1989 (A56435)
Great Dane Van...
