What size bolt/pin for Cat 1 3pt QH top HOOK
   / What size bolt/pin for Cat 1 3pt QH top HOOK #11
Then today I got out of my truck and walked to a tree so I could continue my phone call in the shade. While on the phone I looked down at my feet and there was my top hook. No looking required.
If I had that kind of luck I would have went to town and bought a loto ticket.
Those holes are 1/2" on my top hook. I think bigtiller is referring to the wrench size on a 1/2" bolt head.
Thanks for the measurements. I picked up a couple hitch pins today that were half inch. They looked smaller then I remembered and I thought I would be returning them. But that is exactly what I need.
   / What size bolt/pin for Cat 1 3pt QH top HOOK #13
Do any of you run the bush hog without the top link connected? If so what are the pros and cons? I found that the cut was better without the top link on.
I do all the time if it’s uneven ground. If I’m cutting at the house and not reading any where, I just back up lift the Quick hitch to engage the lower lift pins then shorten the hydraulic top link all the way in. Basically works like a semi mounted cutter, but with out the hydraulically adjusted tail wheels.
   / What size bolt/pin for Cat 1 3pt QH top HOOK #14
I was going to reply to your message yesterday and tell you how unlikely it would be for me to find the top hook given that I have 15 acres and had run all of it with the tractor. No way would I have tried searching with a metal detector
Did same thing with shackle off holder on my FEL....
Dale
2005 Club Car Precedent Gas Cart (A55853)
2005 Club Car...
2012 CATERPILLAR 312EL EXCAVATOR (A52707)
2012 CATERPILLAR...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55315)
BOSS 990 Fuel...
2014 Crossroads Sunset Trail ST33PB14 34ft. T/A Travel Trailer (A55853)
2014 Crossroads...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
John Deere Z997R (A56469)
John Deere Z997R...
