What size boards should I cut on saw mill?
   / What size boards should I cut on saw mill?
Sounds like you have a good plan...
FWIW, B&B siding boards can be installed wet/green as long as the battens are nailed in the center so the siding can "move" under them without splitting as the boards shrink...
That is simple but brilliant.
   / What size boards should I cut on saw mill? #22
Older barns were sided with sawn boards that weren't planed. The ones on my 1930s era barn are about 1/2 thick. If you intend to use this lumber for barn siding, the most efficient thing is to cut them to roughly the thickness you want but allow for some shrinkage. They will shrink less in thickness than in width.
Fine homebuilding has a detailed how to for board and batten siding.
   / What size boards should I cut on saw mill? #23
consider laying out the cutting sequence so the flat sawn are thinner and the quarter/rift sawn contain some four inch nominal sizes and some deeper two inch boards.
   / What size boards should I cut on saw mill? #24
Three other installation details for board/batten. First one is to make the roof overhang sufficient to give the sidewalls adequate protection. The siding that has held up the best on my barn is the siding that is most protected by roof overhangs. Second, I'd strongly suggest having gutters so rain is being carried away from your building and doesn't splash back up onto the siding. The third detail is to bevel the drip edge of the siding. Some would also recommend treating the siding or at least the cut edges with preservative.
   / What size boards should I cut on saw mill? #25
For siding a barn or shed, rough sawn seems to make more sense. There are time and material savings from not planing boards thinner, and the rough sawn surface should help paint/stain adhesion.
   / What size boards should I cut on saw mill? #26
I've got a big pile of 1x1 and 1x2 stickers.
I was making my own stickers on my sawmill. Then I read about not-fully-dry stickers staining the wood they were used on.
Now, for my best woods (oak, madrone), I use furring strips from Lowe's. IIRC, an 8 foot furring strip is a little over a dollar. So for about $10 I can sticker a whole pile of slabs, and not worry about accidentally staining them.
   / What size boards should I cut on saw mill? #27
Without a doubt, I'd have them milled at 5/4", and maybe a few 8/4 if I ever thought I'd need any.
SR
   / What size boards should I cut on saw mill? #28
Milling out stickers is VERY easy to do, and it's good practice with your mill, plus it lets you know that everything is dialed in nicely!
Then bundle them up and they will be dry enough to use in a month or so, the outer ones in a couple weeks or even less,
I use pine or aspen and as long as they are dry I've never had one problem with them!
It's a good use for those 4' long pieces out of crooked tree's or low grade top logs.
SR
   / What size boards should I cut on saw mill? #29
Yes! I had heard before to only put one row of nails into green batts, but until his post I always thought they meant nail 1 side, and do the other when it's seasoned.
   / What size boards should I cut on saw mill? #30
I cut my hardwoods in 3 inch slabs then run them in an ad on Craigslist.
I sticker fresh cut pine on fresh cut stickers. I have not seen dried pine stickers leave anything on Red Oak slabs.
White Oak, around here are prized for trailer board. Full and nominal size 2x6s and 2x8s.
All this is for sale. For myself, I have a wide selection of odds and ends. For a specific project, I cut what I need and air dry them.
No matter what you saw, customers will ask for( or you will need) something you don't have.
My best sellers that sell themselves are full size 8 foot 1x12s and nominal size 12 foot 2x6s in SYP.
The 1x12s are used a lot by bee hive builders and the 2x6s are the most common rafter size and length. They sell like hotcakes here.
Hardwood for shelves should be thicker for planing. At least a quarter inch thicker. Cut them a foot longer than needed to cut off any cracks in the ends.
Fresh cut Red Oak laid on steel turns black almost on contact.
hugs, Brandi
2018 Kubota U17 (A53317)
2018 Kubota U17...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2016 Frieghtliner Bucket Truck (A55973)
2016 Frieghtliner...
1985 Allmand Max Lite III LD30-3CE S/A Towable Light Tower (A55973)
1985 Allmand Max...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
