Grading What size blade for TC24D?
   / What size blade for TC24D? #1
SacandagaBrad
Platinum Member
Southern Adirondacks, NY
TC24D
Any suggestions on size of a rear blade for a TC24D? I ordered a Woods RB72 with the tractor and am still waiting for delivery. One of the guys at the dealer said it is a good match, the other said the RB60 would be better. I will be using it for everything from light trenching, grading gravel road and driveway, to clearing smaller amounts of snow from the road and driveway. On a 45 degree setting, the 72 will make about a 55 inch swath, the 60 will cover the tire track. I also am trying to keep the tractor as light as possible due to my soft ground, so I did not load the tires and will leave the blade on the back for weight when I need it. Both have the same features as far as tilt and angle settings. About the only problem I see is manuvering around tight spots with a wider blade hanging off the back, but it does give another 40 pounds.
Dealer has them both in stock and cost is almost the same, I just need to let them know which one I want before they load everything for delivery.
Brad
   / What size blade for TC24D? #2
Brad
I would go with the largest blade that could be put on your 3ph and rotated past the rear tires.
My <font color="orange"> Kubota </font> B2190 allows me to use a Land Pride RB3572
This may be a heavier duty blade than the Woods you are looking at.
   / What size blade for TC24D? #3
Sacandagabrad
I use the RB72 on my TC18. It will clear the rear tires so I can spin it 360 deg. The blade is heavy, if you have any hills it will lift the front end off the ground. I recommend as much front weight as you can get. I have 160 lb's on the front and both front tires loaded, another 70 lb's. Before I added the liquid in the front tires the front end would still come off the ground while going up hill. It is an extremely well built blade. I have used mine for two years and even moved all the snow we had last year with it ( over 25" ). I use it on 1100' of gravel driveway. I did buy the skid shoes for it another $160, but it is well worth it to keep the gravel in the driveway.
Solo
Solo,
Do you have an FEL? That weighs another 900+ pounds according to the NH specs, and the tractor weighs about 300 pounds more than the TC18. Of course, the distribution of all that weight is what matters. I never thought about it being too heavy for the tractor. Maybe I should wait until the tractor comes in and try both in the dealers yard before making a final decision. Thanks for the input, this is why I ask so many questions!
Brad
   / What size blade for TC24D? #5
Brad
No, I don't have an FEL. I think that trying the RB60 would be a good idea, if you are going to run without the FEL. I do like the RB72. With the FEL you would be alright.
Solo
   / What size blade for TC24D? #6
I would question the 72" blade choice. I have a 60" blade on my TC24D with R4 tires and I have stopped the tractor in its tracks too many times to count.
So the question is WHAT do you want to move with that blade?
In my case I'm moving a bunch of 20 to 50 pound granite cobbles and if you grab too many the tractor simply won't move. I have not tried this tractor/blade combo in the snow, so I don't know what that will do there. I have also stuck the tractor in heavy clay with the blade.
So I would say if you have heavy work, 60" is a maximum. If you are dragging or doing light work, 72" would probably work?
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
1336 (A58374)
1336 (A58374)
READING SERVICE BODY (A58374)
READING SERVICE...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
JRB 54" QUICK ATTACH HANG ON WHEEL LOADER FORKS (A52709)
JRB 54" QUICK...
Front End Loader Fork Attachment 20,000 lbs 5 foot (A59213)
Front End Loader...
