Grading What size blade for TC24D?
   / What size blade for TC24D? #1
SacandagaBrad
Platinum Member
Southern Adirondacks, NY
TC24D
Any suggestions on size of a rear blade for a TC24D? I ordered a Woods RB72 with the tractor and am still waiting for delivery. One of the guys at the dealer said it is a good match, the other said the RB60 would be better. I will be using it for everything from light trenching, grading gravel road and driveway, to clearing smaller amounts of snow from the road and driveway. On a 45 degree setting, the 72 will make about a 55 inch swath, the 60 will cover the tire track. I also am trying to keep the tractor as light as possible due to my soft ground, so I did not load the tires and will leave the blade on the back for weight when I need it. Both have the same features as far as tilt and angle settings. About the only problem I see is manuvering around tight spots with a wider blade hanging off the back, but it does give another 40 pounds.
Dealer has them both in stock and cost is almost the same, I just need to let them know which one I want before they load everything for delivery.
Brad
   / What size blade for TC24D? #2
Brad
I would go with the largest blade that could be put on your 3ph and rotated past the rear tires.
My <font color="orange"> Kubota </font> B2190 allows me to use a Land Pride RB3572
This may be a heavier duty blade than the Woods you are looking at.
   / What size blade for TC24D? #3
Sacandagabrad
I use the RB72 on my TC18. It will clear the rear tires so I can spin it 360 deg. The blade is heavy, if you have any hills it will lift the front end off the ground. I recommend as much front weight as you can get. I have 160 lb's on the front and both front tires loaded, another 70 lb's. Before I added the liquid in the front tires the front end would still come off the ground while going up hill. It is an extremely well built blade. I have used mine for two years and even moved all the snow we had last year with it ( over 25" ). I use it on 1100' of gravel driveway. I did buy the skid shoes for it another $160, but it is well worth it to keep the gravel in the driveway.
Solo
Solo,
Do you have an FEL? That weighs another 900+ pounds according to the NH specs, and the tractor weighs about 300 pounds more than the TC18. Of course, the distribution of all that weight is what matters. I never thought about it being too heavy for the tractor. Maybe I should wait until the tractor comes in and try both in the dealers yard before making a final decision. Thanks for the input, this is why I ask so many questions!
Brad
   / What size blade for TC24D? #5
Brad
No, I don't have an FEL. I think that trying the RB60 would be a good idea, if you are going to run without the FEL. I do like the RB72. With the FEL you would be alright.
Solo
   / What size blade for TC24D? #6
I would question the 72" blade choice. I have a 60" blade on my TC24D with R4 tires and I have stopped the tractor in its tracks too many times to count.
So the question is WHAT do you want to move with that blade?
In my case I'm moving a bunch of 20 to 50 pound granite cobbles and if you grab too many the tractor simply won't move. I have not tried this tractor/blade combo in the snow, so I don't know what that will do there. I have also stuck the tractor in heavy clay with the blade.
So I would say if you have heavy work, 60" is a maximum. If you are dragging or doing light work, 72" would probably work?
New Idea Manure Spreader (A50515)
New Idea Manure...
3 pt Ditcher Plow (A50515)
3 pt Ditcher Plow...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
