What size battery for mighty mule
   / What size battery for mighty mule #11
+1 on the deep-cycle. I bought mine at Academy, and it works great on my 350. I have MM solar panel...
Did you put in any kind of protection so the battery does not overcharge?
   / What size battery for mighty mule #14
For the smaller chargers say about 5 ~ 15 watts you probably won't need a charge controller as the current isn't that much (15w/13v(recommended)=1.15a) which is basically a tricklecharger. The solar panels have builtin protection to keep from discharging the battery at night. I run a 5w panel for my trailer mounted winch (8500#) with a standard deep cycle battery. Works great. Have another setup on my horse trailer for the living quarters which is 45w through a controller to 2 AGM batteries. No problem with either setup.
   / What size battery for mighty mule #15
Guess I need to google that point. Can you over charge a 12v battery with a solar panel? If so how do you cut it off?
Just get on Amazon and get a solar charge controller...that's what I did and bypassed the RM350 controller.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
2007 FORD F650 XL SUPER DUTY FUEL & LUBE TRUCK (A51406)
2007 FORD F650 XL...
CATERPILLAR D11T HI TRACK CRAWLER DOZER (A52705)
CATERPILLAR D11T...
