What size Baler can the FORD 2000 GAS TRACTOR PULL
   / What size Baler can the FORD 2000 GAS TRACTOR PULL #11
Only reason new "modern" sq balers require more HP than older balers is they have more capacity BUT one can slow down and not rake as large a windrow to require less HP
   / What size Baler can the FORD 2000 GAS TRACTOR PULL #12
Bigfoot62,
Please tell me why "modern" square bailers require more power than the older ones. I can't figure it out.
Stuck
What Jim said.
Maybe instead of "modern" I should have used the word "current." I got my info from JD, NH, etc. websites.
   / What size Baler can the FORD 2000 GAS TRACTOR PULL #13
Another data point:
I used to pull a NH 268 baler ('68 vintage) with a Ford NAA (31 PTO hp, 4spd, no live PTO) and it worked well enough. You had to make sure the windrows weren't too big and most baling was done in 1st-2nd gear. If there was a big clump of hay or broken bales to be rebaled I'd go spread it out by hand since you couldn't ease into it like with a tractor with live PTO.
   / What size Baler can the FORD 2000 GAS TRACTOR PULL #14
I got one of them 35hp Chinese tractors that I pull a NH 269 with and just like the others here say, I just slow down. I don't have a large area to do so I just putt putt along and get my job done just fine. bjr
   / What size Baler can the FORD 2000 GAS TRACTOR PULL #15
My MF124 baler (two twine, small squares) is rated at 35 hp (pto). But balers this size have been run with much smaller tractors. Like this Farmall Super A in this video.
FARMALL Super A - YouTube
The baler portion occurs about 6 minutes into the video. That Super A has less than 20 hp on the pto.
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
2011 John Deere 5085 70HP Utility Tractor (A55973)
2011 John Deere...
2026 Quality Steel Dump Trailer (A56858)
2026 Quality Steel...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
