Backhoe What size backhoe bucket?
   / What size backhoe bucket? #11
I wanted a thumb, the dealer had a decent price on a thumb, but said it only came with the 16" bucket.
One of my primary uses will be digging stumps. Does the collective wisdom recommend I get another, smaller bucket also?
If you have a thumb, I don't think you are supposed to use a 12" bucket at all.
On my JD TLB 110, the thumb pivots on a pin which is also the bucket pivot pin. Installing the thumb requires replacing the stock pin with a longer one. You do not really want to do any digging at all with a pivot pin longer than the bucket is wide. If you dig a narrow trench, you will be dragging the grease fittings on the ends of the pivot pin through the dirt on both sides of the trench.
This worked out well. I bought a used TYM backhoe and it came with both a 12" and an 18" bucket. Now if I can just get the subframe fabbed up to my tractor, I will get to try both =]
Marcus
   / What size backhoe bucket? #13
Bucket size depends on usage.
Start with the standard bucket unless you are sure that you will require a different with based on your primary application.
My standard bucket is a 16". I have a 9" for water and electrical lines. I am building a frost tooth for rocks and roots. I would like to get or fabricate a wider shallow bucket for grading in the 24" to 30" range.
A wider bucket is ok to use, but use discretion and switch to a narrower bucket when the going gets tough.
I used to deal with several large road contractors. Bucket choice was determined based on application as well as location.
   / What size backhoe bucket? #14
Newberry, I have the Woods BH-80X with 9" bucket and factory thumb, it works fine.
Mike
   / What size backhoe bucket? #15
I have a 24 and an 18 for my 8 1/2 ft Amerequip (generic) Hoe.
On the way home I got to thinking that I really should have got a 12 and a 24, but I was hauling the hoe and buckets back from Harrisburg PA to Mass and was too far into the journey to turn around a reneg the deal.
I still havn't put the 18 on, it is still "new and unused".
If I had to have just one bucket it would be the 18, but given that I have the 24 a 12 would be a much better choice for a second bucket.
If anyone wants to swap a new/new'ish 12 for an unused 18 you can contact me, the pin for pin compatibility of Amerequip hoes has been discussed here in a few different places, they OEM for Deere, Montana, Branson/Century/Kukje and others that I don't recall right now.
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
2007 CATERPILLAR D5G XL CRAWLER DOZER (A52707)
2007 CATERPILLAR...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2022 Cub Cadet Ultima ZT1 54in Zero Turn Commercial Mower (A55851)
2022 Cub Cadet...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2020 Sellick S80 (A53317)
2020 Sellick S80...
