What size auger for chainlink fencing?
   / What size auger for chainlink fencing? #1
BamaRob
Platinum Member
Alabama
Mahindra 2615 4WD
Long story short...
My mother has offered to purchase a posthole digger for my tractor if I'll dig the holes for installing chainlink fencing around my sister's lawn. Of course, I agreed! It'll be a KingKutter brand and they offer 6", 9", and 12" augers. I'm assuming the 6" is what I'll need for installing the posts for chainlink fencing, correct? Or, should I go with one of the larger augers and just use more concrete/fill around the posts?
Thanks for any advice,
BamaRob
   / What size auger for chainlink fencing? #2
I'd stick with a 6", smaller, faster, less concrete.
Thanks for the prompt reply. I found a fencing site that recommends digging the hole 3 times the diameter of the posts. So, a standard 2" diameter fence post would call for a 6" diameter hole. The 6" auger sounds like what I need.
Thanks,
BR
   / What size auger for chainlink fencing? #4
do your self a favor and get a 9 inch< you will regret the 6 inch when you go to put in a 4x4 or 6x6 post. post hole digger has a lot of uses. Don't limit yourself with a 6 inch
   / What size auger for chainlink fencing? #5
Depending on your soil type and room you could use the loader to push them in. We've done many times with Tpost.
Jeremy
   / What size auger for chainlink fencing? #6
Jeremy is correct, soil type will be the big factor, red Alabama clay 6" is great.
I have a 6" and 12" auger and I can see uses for 9" and 18" augers, tractors take a lot of yor money.
steve
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2005 Nissan Frontier 4x4 Pickup Truck, VIN # 1N6AD07W35C433334 (A51572)
2005 Nissan...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
BUSH HOG 3308R-2 LOT NUMBER 118 (A53084)
BUSH HOG 3308R-2...
2021 New Holland C327 Compact Track Loader (A53472)
2021 New Holland...
