What size auger bit do you use the most?
   / What size auger bit do you use the most? #1
Lucky_Ducky
MX6000 w/ cab
what size auger bit do you use the most?
   / What size auger bit do you use the most? #2
I use my 5/8” auger in my Stihl gas drill the most for thru-bolts on fence posts
   / What size auger bit do you use the most? #3
Planting bushes or trees, 12"
Planting posts with concrete, 9"
Planting posts with dirt, 6"
I've done all of them about equally... maybe trees and bushes a tad more.
   / What size auger bit do you use the most? #4
I use a 9" the most, because that's all I have! It's just barely big enough for split rail posts
How large are the bushes/trees you plant?
   / What size auger bit do you use the most? #6
Bare rooted trees but have done gallon pots. Nothing super big like large root balls. 12" breaks up the soil enough that you can dig the hole larger if needed.
I will dig a deeper hole than I need, then cave in the side walls for larger holes.
   / What size auger bit do you use the most? #7
I have a 12 inch and a 6 inch. The six inch goes into the ground so fast that I cannot control it. Then I have to use my backhoe to pull it out of the ground!!! I've removed the teeth from it and put them on my 12 inch auger, when they wore out, and never replaced them on the 6 inch auger. I use the 12 inch for everything.
   / What size auger bit do you use the most? #8
So far I have use my 12". I have a 6" for my 4x4's.
Anybody know about a threaded auger attachments? Not the standard square with a pin.
   / What size auger bit do you use the most? #9
I use the 9" most for 4' posts as it allows me to use a tamping bar around it when back filling dirt. For corner posts I use a 12" as they are larger in diameter. I only backfill with dirt as I have had bad luck with concrete. I have 6", 9", 12", and 18" augers.
   / What size auger bit do you use the most? #10
I see that the augers that will drill threw stone are over $1K ??
willy
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
