What should I use?
/ What should I use? #21
If the homeowner won't keep it wet, you're wasting your time.
/ What should I use? #22
/ What should I use? #23
I found out that the straw is to keep it shaded
so that the sun doesn't scorch it.
Kinda like when you're out swimming all day in the lake without sunscreen.
You get a real bad sunburn from this.
The straw is sunscreen for the seed.
Gotta keep it wet. Sprinklers that simulate a good gentle rain are best.
Pooh Bear
/ What should I use? #24
Pooh Bear
/ What should I use? #25
<font color="blue"> I found out that the straw is to keep it shaded
so that the sun doesn't scorch it. </font>
Straw also helps prevent erosion and helps retain water for the seeds.
/ What should I use? #26
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
Dexter trailer axles (A61567)
Dexter trailer...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
