Comparison What should I get a John Deere 212 or a Cub 1862?
   / What should I get a John Deere 212 or a Cub 1862? #1
flyweed
Southwestern Wisconsin
Cub Cadet GT2544 & LX1050
I have a chance to buy either of these locally, comes with mower decks, front snow blower and each also has a rear tiller (If I remember right). Price is about the same on each.
Just wondering, if you could only choose one, which would it be and WHY ??? I have a couple days to think it over, but can only pick up one of them.
So what are pluses and minuses of the JD 212 and the Cub 1862?
Do these both have front and rear hydraulics? I am going to be using this as my main snowblower, on a 200ft uphill driveway, and also hilly mowing in the summer
Any help would be great.
Thanks
Dan
   / What should I get a John Deere 212 or a Cub 1862? #2
The biggest reason is the cub is a hydro trans and the deere is gear.
so are you saying go with the Deere or the Cub?? which one has more bang for my buck as far as power wise?
   / What should I get a John Deere 212 or a Cub 1862? #4
All of those implements are easier to use with a hydro transmission that the cub has and the deere does not. The cub also has 50% more horsepower. Condition being equal? I'd probably pay $3-$400 more for the cub.
ok.what about a JD 317 or a Cub 1862?
   / What should I get a John Deere 212 or a Cub 1862? #6
Id go with the Cub since it has a hydro trans. It will work better with the blower and for mowing grass. You could run a power angle blade on the cub, I'm not sure how they did the hydraulics. The Cub is a more modern machine.
   / What should I get a John Deere 212 or a Cub 1862? #7
Personally I'd hold out for a '93-'01 Deere 425,445,or 455. There are a few versions of 317 with some being quite undesirable.
   / What should I get a John Deere 212 or a Cub 1862? #8
Either of the two JD models are upwards of 40 years old. Your advice is solid. Look for something newer. Parts could be at issue.
   / What should I get a John Deere 212 or a Cub 1862? #9
The JD 212, 317 both had a varible speed feature that is being obsoleted by JD so parts are getting harder to find. I am a big fan of the old deeres but the parts availabilty makes them less desireable for the go to tractor.
Agree with look for newer models since they have auxillary hydraulics and turn much shorter than the older JD models. Not familiar with Cub model but if made by MTD the quality is not what the original cub cadets where...
   / What should I get a John Deere 212 or a Cub 1862? #10
That's not true they are still a good machine, just not the ones you get at the box store. They sold out to MTD in 1981.
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2016 R and R Products 331 LP Reel Mower (A55851)
2016 R and R...
2025 GIYI PG72 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 GIYI PG72...
2014 King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
2014 King Kutter...
Swict 66" Quick Attach Bucket (A56469)
Swict 66" Quick...
