what should go in a trailer toolbox
   / what should go in a trailer toolbox #1
mdbarb
Northern California
B21
OK Ive got my B21 with 4:1 loader, backhoe, box scaper and post hole digger, just ordered my tiltometer, figured out which trailer to get.
Next question - I want to mount a small toolbox on the trailer. What should go in the toolbox? Mind you, I won't be doing any rebuilds in the field, but what are the must haves? pins, clips, nuts, bolts, wrenches, a really big hammer.....?
   / what should go in a trailer toolbox #2
mdbarb,
Be sure to add a strong 3/8" chain to your list of things for the toolbox.
DaveV
   / what should go in a trailer toolbox #3
A first aid kit with "big" bandaids (Duct tape works well)
Bailing wire
A pencil and paper to start your book "101 things not to do with a tractor"
   / what should go in a trailer toolbox #4
I've been hauling a tractor to some other property 100 miles away (no more, I'm putting a storage box up there!) It's 25 miles to the nearest auto parts store.
I never could out guess the crazy things that would happen. I am doing land clearing and everything else, so the tractor is vulnerable to attack from a lot of different directions. When the hoses started looking bad I measured them and had a new set built.
Nice big light colored good tarp for putting on the ground so you can find the nuts and bolts you drop!
Come-along, tow strap, a MAJOR first aid kit. Extra hydraulic fluid and diesel in case you really screw up and drain it to the point of not being able to get it back to the trailer. One of those tanks you can put pressurized air into. You probably can't fix a flat unless you're good with one of those plug kits but a couple times I managed to get the tire wrenched around enough that the bead let the air out. Every possible tool you can carry if you're going to be out in the wilderness. Fan belt, rad hoses, antifreeze, boy I could go on for ever. If you are going to a particular place try to make friends with a neighbor, do some odd jobs for them with the tractor. When you get your truck stuck trying to pull your tractor out, or you need that flexible 29mm socket and you forgot your 3/4 to 1/2 adaptor, a good friend will be a god send.
And if I might diverse a second (do I ever talk for just a second?) on the hydraulic hoses...
When I first got my tractor I had to order a hose from Ford NH. It was a zillion dollars and took a week. My neighbor who works on equipment for a living slapped me around pretty good, and told me next time to go to a hose outfit, in my case Timco in Tacoma Washington.
The hose that was about $35 from Ford...? When I took a longer one in he asked if I wanted to use the old fittings or get new ones. I asked what the difference would be. The cost of a new hose with my old fittings was about $4, with new fittings was $6! Those guys have been wonderful. I do have to swallow my pride though, seems like everytime I go in they look at my stuff and giggle and say "What's THAT for?" Most of their work I think is big 2" hoses, 3-4 who knows how many layers for god knows how many PSI. My little dinky ones...I usually say it's for the HYDRAULIC SEAT on my TRACK HOE down at the Centralia Coal Mine.
   / what should go in a trailer toolbox #5
md, I carry what you carry. In addition, I carry Duct tape, plug kit for tires, screw drivers (regular and phillips), washers, plastic guard to cover PTO shaft, and a magnetic level (to level 3 point implement). This winter I want to mount a bigger tool box.
   / what should go in a trailer toolbox #6
If you've seen my tractor and trailer picture in the tractor photo section, you've seen how big my toolbox is. It's mostly for chains and tiedown straps. A couple of crecent wrenches (SAE and Metric) and pliers and a pry bar and a jack and spare hitch pins and "stuff". Road flares, clevis (clevi?), bug spray, what else?.......
   / what should go in a trailer toolbox #7
Stevepio, what's the difference between an SAE and a Metric "crescent" wrench?/w3tcompact/icons/wink.gif
Bird
   / what should go in a trailer toolbox #8
The SAE would be "Crescent" and the Metric would be "Croisant", right?
/w3tcompact/icons/wink.gif Bill
   / what should go in a trailer toolbox #9
Very good, WVBill./w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Bird
   / what should go in a trailer toolbox #10
A spare tire! I do not have a equipment trailer, but friends of mine who do, don't have spare tires. A couple of them have brand new trailers! It would be just lovely to have to leave the tractor and trailer on the side of the road while you try to have a flat fixed...
Also, throw in a few extra bulbs, and a spare brake/tail lamp assembly. It's funny how fences, mail boxes, ditches, ect tend to reach up and grab a tail light when you're backing up /w3tcompact/icons/shocked.gif
RobertN in Shingle Springs Calif
7046 (A50322)
7046 (A50322)
Unused 2025 CFG Industry MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
2014 Ford Escape SUV (A50324)
2014 Ford Escape...
2000 Ditch Witch 3700DD Ride-On Trencher (A50322)
2000 Ditch Witch...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
1995 Western Star 4900 T/A Wrecker Tow Truck (A50323)
1995 Western Star...
