What should AC temp.be at vents in cab of new M110
   / What should AC temp.be at vents in cab of new M110 #1
burtt
I just purchased a new Kubota M110 with cab. It didn't seem to be getting cold enough in the cab. With the temperature at 80 degrees outside it is only getting down to 58 degrees in the vents. Does anyone know what the temperature should be or can someone tell me where I can look to find out?
   / What should AC temp.be at vents in cab of new M110 #2
I did a bit of hunting around after checking out the Chevy forum (I also play with an old truck, as well as my tractors). I found this on an air conditioning company's web site as the temp that they would expect from one of their systems:
3. CENTER DUCT TEMPERATURE ( 36-46 DEGREES F.)
Don't know how that should translate to a system on a tractor, but I'd guess that 60 degrees is a bit on the high side. They do have different numbers at various RPMs for the compressor, but the output temp remained the same.
On the other hand, that's lots cooler than the air that hits me on my non-cab, non-conditioned tractor /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif. But for a new unit, I'd expect that at a reasonable 85 degrees that it should turn your cab into an icebox.
40ft Sea Container (A52384)
40ft Sea Container...
Light Tower (A52377)
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
