What rpm and range to use when working?
   / What rpm and range to use when working? #1
GARBLUES
N.Y.
TC30
What range ( L M H ) and rpm setting does one use when bush hogging, plowing, grading, and just riding around in an open field ( for the fun of it )?
   / What rpm and range to use when working? #2
When bushhogging.. i think it is best to use the rpm setting that makes your pto rpm match the recomendation of the mower. in other words.. choose the engine rpm that gives you, for instance, 540 pto rpm.. for a standard pto.. etc. Choose gear or range then to get a good safe ground speed.
For just riding.. I generally use a lower rpm.. what ever makes for a good range/gear combination of ground speed, but keeps the engine from lugging.
Grading is also a lower than mowing rpm.. though higher than joyriding.. enough rpm, in whatever travel gear/range you are using to not lug the engine down when making a windrow.
Plowing.. i pretty much use 'mowing' rpm... you drawbar hp is rated on the engine hp at a hig working rpm. A plow is a high draft implement.. you need the rpms up..
Mind you if you are toting a 1-12" bottom on a 6000# tractor with 100 hp, you could obviously reduce that engine rpm to a lower setting, as there is 'excess' power.. or 'insuficient' load.. etc.
Soundguy
   / What rpm and range to use when working? #3
Listen to the tractor and the feel of your britches, they will tell you what is best. As for pto speeds, rated rpm is what they are designed for.
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2004 Chevrolet (A53422)
2004 Chevrolet...
2011 Mitsubishi Outlander AWD SUV (A51694)
2011 Mitsubishi...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
