What rear remotes to go with
   / What rear remotes to go with #11
I have self cancelling detent and a float.
I use the float valve for all attachments and only use the detent if I need two remotes for a machine.
I much prefer the "feel" of the float lever, and I run a couple single acting cylinder machines so the float position gets used all the time.
   / What rear remotes to go with #12
Is the valve stacks from surplus center that say check valves are pilot operated? Where did you get your remote valve?
I would imagine if they have check valves they are pilot operated check valves.
It has been 16 years since I installed my remotes. But there is a thread here at TBN with all the details if you have the endurance to read through it. :D
Here is the link (I hope):
https://www.tractorbynet.com/forums...r-ending-t-t-path.html?highlight=Never+ending
   / What rear remotes to go with #13
Thanks for the link. Impressive fabrication and documentation you did adding remotes. Many good ideas.
You mentioned shrouds. Any heat or leak problems? Any abrasive covering needed to the work lines?
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
UNUSED FUTURE FT-CWG72-72" HYD CURVED WOOD GRABBER (A57193)
UNUSED FUTURE...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
Electric Mobility Scooter (A54815)
Electric Mobility...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
