What plow for JD 5525?
   / What plow for JD 5525? #1
exiled cheesehead
I have a JD 5525 4WD tractor with loader and liquid filled R1 tires. It weighs around 9,200 lbs and is rated at 91 engine hp. I need to plow red clay soil (with a couple inches of top soil) with rocks mixed in. In addition, the land is well sodded over and there are roots from small woody vegetation and some trees mixed in. I have an old 8 foot heavy duty JD bog disk that i have used in the past on the property and it has worked fine. However, when I tried the disk on the new field described above, the sod didn't bust up much due to the mass of roots in the ground. I went over the area 5 times with the disk and wasn't satisfied with the results. So, I need to change my tactics. I will add that this is a pasture renovation and the size of the field is about 5 acres. I expect to have similiar projects in the future on other parts of the property, so I want to buy a quality piece of equipment that will hold up well over the years.
Here are my questions:
1. What type of plow should I buy? Moldboard or Chisel?
2. Should the plow be a 3 pt (cat 2) attachment or pull behind?
3. What size plow can my tractor handle in these soil conditions?
Thanks for the advice.
   / What plow for JD 5525? #2
I use mine for similar situation when my disc just doesn't sink in. I restored an old three bottom Ford 101 plow with shear pin trip protection. Pull it with a 70 hp Kubota (4 WD, loaded rears) It pulls easily. I would think you could go with a four bottom or even five, but whatever you get, make sure the trip protection works well, as I often hang up on rocks or large roots and break a pin. THe shear pins are easy to fix, only takes a couple of seconds. SPring reset trip would be nice to have, but the shear pin system is easy and simple. I don't know anything about chisel plows.
I plowed our food plots yesterday. It really rips through the tough sod in one pass whereas the disc would not have even penetrated as it was really dry and hard.
   / What plow for JD 5525? #3
We have the 3 point chisels and a disc plow would also be good in roots and rocks. Ken Sweet
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
