What pallet forks work on my tractor?
   / What pallet forks work on my tractor? #11
Ok...imagine putting 10k rated forks on a SCUT. Some of them could barely lift the forks and frame, much less a pallet of anything. A quick look online, I found a set that weight 875 lbs. That is more than the lift capacity of a BX. Point being, just because it fits, does not necessarily mean it will work.
10k rated forks with SSQA would be extremely rare. 4,000 would be way more common. Putting 4K forks on a tractor isn’t the best possible combination but it’s not hurting your capacity that bad compared to the right forks. And if you have a SCUT you should probably be buying implements directly made for it vs buying skid steer attachments.
   / What pallet forks work on my tractor? #12
It was not about what was common, but what could be imagined. A quick internet search found 10k forks. They are most likely used on skid steers, but when you dream, dream big!
   / What pallet forks work on my tractor? #13
Sticker on Bobcat forks.
I guess I see how that tells you how much the forks can take but not what size/horsepower tractor they can go on unless I’m not reading it completely.
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
COMAC 72' HYD ROCK GRAPPLE BUCKET (A57192)
COMAC 72' HYD ROCK...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
22ft Rollback Flatbed Body with Winch (A55852)
22ft Rollback...
2017 Ford Transit Connect XL Cargo Van (A55852)
2017 Ford Transit...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A55315)
2016 RAM 5500...
