what opens a .dwg file ?
/ what opens a .dwg file ? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Got some site plans sent to me today in .dwg format...
I've got no clue as to what program I can use to open or view them.. anybody else?
soundguy
/ what opens a .dwg file ? #2
You can Google .dwg and there are many examples of viewers that pop up. Infograph has a free viewer that I heard was pretty good have not tried it myself.
/ what opens a .dwg file ? #5
Autocad or some similar program will but they're spendy.
I had the same situation a while back and did as blizzard suggested - found a freeware program. Used it long enough to convert the file to Visio- compatible format then uninstalled it. Don't remember its name.
I figured it would be autocad.. just had no way to verify..
thanks
soundguy
/ what opens a .dwg file ? #7
Irfanview (a free program) will open just about any graphic file there is. Don't forget to download and install the plug-ins.
Download IrfanView
Of course, you wont be able to manipulate the file, but you can print it.
/ what opens a .dwg file ? #8
If you'd like to send it to me I'd be happy to open it and convert it to .pdf for you. I can PM you my email if you'd like.
/ what opens a .dwg file ? #9
Microstation's Bentley View is a free download that will open microstation and autocad files for viewing, and you can print as pdf's. I couldn't get Irfanview to open one, but maybe I don't have a plugin
thanks guys!
soundguy
/ what opens a .dwg file ? #13
TurboCAD V 7.1 will save and open .DWG
thanks
soundguy
2014 Bobcat E63 (A64126)
2014 Bobcat E63...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
CASE CX160C EXCAVATOR (A65053)
CASE CX160C...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
1500 Gallon Stainless Steel Tank (A64127)
1500 Gallon...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
