what on earth does electricity cost near you?
   / what on earth does electricity cost near you? #852
610 KWH (the past month) Electricity = $0.09/kwh plus Delivery charge = $57.42 plus Regulatory Charge $4.28 plus HST = $15.39 minus Ontario electricity rebate $15.51 TOTAL= $118.30
With all those charges and minuses I take the total that I shell out of my pocket divided by the total kilowatt hours I used and that is what it co$ts me. 118.30/610=$0.1939344262295082/KWH. From November 1 through April 30th I get 1,000 KWH at his price.
Northern Ontario, Canada
   / what on earth does electricity cost near you? #853
Here is my running average usage/price.
YearKWPrice$/KW
2015493$72.37 $0.147
2016650$94.59 $0.146
2017590$92.06 $0.156
2018503$78.88 $0.157
2019583$87.06$0.149
2020594$87.78$0.148
2021740 $ 107.02 $0.145
2022741$117.56 $0.159
2023748$142.39 $0.190
2024485$106.33 $0.219MeterDown Beginning of Year
2025179$36.42 $0.203
   / what on earth does electricity cost near you? #854
My biggest problem…..we use too much kwh per month. Can't figure how to cut down. Have switched to nearly all led lighting. Mostly all gas appliances. I know in the winter i do have some heat tape and heated water troughs that have to be used, but even in Summer its too high.
   / what on earth does electricity cost near you? #855
Maybe tracking individual devices with a Kill A Watt?
2500 square feet 1950’s California split level home with single pane windows, no floor insulation and 1960’s garage freezer and 1970’s refrigerator plus electric stove, oven and dryer runs 360 kW each month summer and winter with little variation.
   / what on earth does electricity cost near you? #856
Hot water and heating with electric are the biggest users of kwh
Im around 2500kwh/mo in the winter months, ~1200-1300kwh in spring and fall with little to no HVAC and 1800kwh/mo in the summer with AC
Still blows my mind some get down sub-500kwh per month. But 2 kids, lots of laundry, showers, a dusk-dawn security light, 3 fridges and a freezer, a 3600gph goldfish pond pump....we still use quite a bit even taking HVAC out of the equation
   / what on earth does electricity cost near you? #857
just a touch over $0.20 per kwh,
we also use quite a bit of electricity most every month
   / what on earth does electricity cost near you? #858
Then again…. I just went into electric heated tack room and wifes garden shed with 3 racks of grow lights for her garden starts and electric heater…..maybe its all her fault
   / what on earth does electricity cost near you? #859
Ironically, now that we're back in the 20ish°F, I'm using my 18K Mitsubishi Hyper Heat, heat-pump to heat my house (only the upstairs, not my walk-out basement facing the lake) because it costs only about $40-45 a month compared to using my boiler's operating cost with propane and the taco recirculation pump that costs more. I originally installed the heat-pump back in 2016 for my mother's benefit (when she was alive) because I didn't want her to suffer in the summer heat, but eventually experimented on the operating cost of heating the upstairs and letting the downstairs buck (so long as it didn't get freezing temps for the pipes down there) one November just to see what it did cost.
Anyway, I now install heat pumps for people in my area since I bought all the tools and use three-cycles of pressurized nitrogen and vacuum to both test for leaks dry out the mini-split lines (which is what is necessary in order to get the hyper efficient mini-splits down to their crazy efficiency numbers) before filling with 410A.
All to say, go team electric!
Oh, if you do go with a heat-pump and you live where it genuinely gets cold, add the optional heat plate to the outdoor condenser so it cannot freeze up, and for convenience sake a Honeywell remote controller is also nice.
Oh and considering Building HVAC systems use single flares, I HIGHLY suggest using these fun gaskets at the flares even though I make nice flares because they help prevent leaks at the flares.
   / what on earth does electricity cost near you? #860
@MinnesotaEric that sounds great! Thanks for the tip on the seals. Can you elaborate a bit on the nitrogen / vacuum purge process as to why it is particularly important for the Hyper heat systems? (I thought dry was important for all HVAC...)
All the best, Peter
20 ft. Shipping Container (A53117)
20 ft. Shipping...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2008 New Holland B110 MFWD Loader Backhoe (A53473)
2008 New Holland...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
