What oil weight
   / What oil weight #1
Larry_T
wis
kubota L3010
Live in WI. I can not decide Mobile 1 or amsoil what weight for year around. Kubota L3010 We are talcking synthetic.
   / What oil weight #2
eather mobil or amsoil.. the only weights that meet CI-4 would be 5w30,0w40,5w40 and 15w40 the best bet probaly would be 0w40 or 5w40 since u said year round.. products would be mobil delvac 1 or amsoils 5w30 series 3000 would work. chevron has a 0w40 ci product too.
   / What oil weight
how inportant do you guys think the lower number on oil weight is. how much diffrences dose it make. Larry
   / What oil weight #4
difference in cranking and not.. and spinning a bearing and not in extreme cold.
Otherwise once hot nothing..
   / What oil weight #5
If you have to start your tractor at -40, use 0w40. If warmer than that, 5w40 would be fine. The lower the first number is, the faster the oil gets to your overhead valve train in cold weather.
Exxon did some research a few years ago (about 1990ish) where they showed an overhead cam engine being started at -40. The engines had transparent overhead valve covers for the camera to film how well the cam assembly was doing. Unless a 0w oil was used, the cam assembly would start smoking after a few seconds. It took several seconds for a higher weight oil to get pumped up to the cam assembly. The only oil available at that time that was 0w was synthetic. Our Canadian affiliate was looking at making a 0w30 non-synthetic at that time. Since then, EM and Chevron have non-synthetics that are virtually the same as synthetics, just made by a different route (and from less expensive feedstock than the true "synthetic" PAOs are made from).
Most wear occurs at startup. Almost all research has shown this, too.
Ralph
   / What oil weight #6
301o,
Just my 2 cents, I'll be using the Amsoil series 3000
   / What oil weight
in otherwords you guys are saying that lower number is of concern in cold weather. in warm weather it would not be a factor, so a 5w40 or 10w40 would be fine. year around. Larry
   / What oil weight #8
The all seem to weigh about 1 pound or so per quart.
Sorry just could not resist /forums/images/graemlins/smile.gif
   / What oil weight #9
</font><font color="blue" class="small">( The all seem to weigh about 1 pound or so per quart )</font>
Last I knew, a pint was 16 fluid ounces and a quart was 32, so make that 2 pounds or so per quart.
Sorry just could not resist. /forums/images/graemlins/smile.gif
   / What oil weight
well you 2 guys is it one or 2 pounds?? or so
2020 Terex RL4 Towable Light Tower (A53421)
2020 Terex RL4...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
