What Oil/fluid should I use
   / What Oil/fluid should I use #1
cowboyffa84
Yanmar 4300
I used to have a website that told me what weight oil and what transmission fluid I should use, but I ended up losing it. So I asked the dealer I got my tractor off of and they said just use whatever... sounded like they didn't even care to help and hung up on me. I don't want to put something in there that might mess up my tractors.
I have 2 tractors both yanmars ones a 1500d 2wd without a loader. I want to change the engine oil and tranmission fluid and need to know how much for both.
Then I have a 4300 yanmar 4x4 with a loader. I have to change the knuckle seals and need to know what type of fluid to put back into the 4x4 caseing and how much.
I know I sound like a dumb butt and all but id rather be safe then sorry and make sure im doing it right Thanks alot for any help.
   / What Oil/fluid should I use #2
Can't help with how much.You should have a dip stick . just put some in & check. My 3110 holds a little over 5 gallons of HYD fluid. Hyd fluid should meet JD 303 specs. Any 15w40 diesel rated engine oil 75w 80 or 90 wt gear oil tor the front gears
   / What Oil/fluid should I use #3
the 1500 barely holds 4 litres of engine oil, a good 15/40 diesel oil is fine, the trans/hydraulic holds about 14 litres so a trans/hydraulic oil is required for this (JD 303 or equivalent). the front diff uses 90wt. as for quantities of oils for the 4300 probably double the 1500s quantities........:laughing:
   / What Oil/fluid should I use #4
I use Amsoil 15/40 in all of mine and their top trans fluid for the rear/trans/hydraulics (Torque-Drive).
Lengthens oil changes and gives a little extra protection with thermal breakdown.
   / What Oil/fluid should I use #5
I notice my YM336D service manual recommends 30wt (and only 30wt) for anything above 50F. It doesn't even mention 15w-40.
Is 15w-40 new? Is it a safe replacement for straight 30wt?
   / What Oil/fluid should I use #6
I have a YM1300 it use 2.2 liters for the motor and 9.5 liters for tranmition, for the motor i use Delvac 10W140 for diesel motor and i have problems tu find out JD 303 in Chile my home country, any one have any sugestion, the guys form John Deer Chile sugest Hy-Guard but it is diferent than J14B
   / What Oil/fluid should I use #7
All the XxY type oils are newer than the tractor. 30w oil is old technology. A good synthetic will allow you to run a thinner weight oil whilre still protecting the engine.
   / What Oil/fluid should I use #8
I have problems to find out JD 303 in Chile my home country, any one have any sugestion, the guys form John Deer Chile sugest Hy-Guard but it is different than J14B
Hy-Gard is a newer, better quality Deere specification that replaces JD303. In our old Yanmars, the only difference is Hy-Gard doesn't get as thick in cold weather so the tractor warms up faster. (And it may be more expensive than JD303).
Here is a discussion with some name-brands that may be available in Chile - Shell, Chevron, etc.
Substitute for John Deere Hy-Gard J20D? - Bob Is The Oil Guy
Here in the US there are store-label brands that are less expensive than those name-brands. You might find that in Chile also. If the container says 'JD303' that should be sufficient.
   / What Oil/fluid should I use #9
Thanks for the advise, I find the Hy-Guard hydraolic oil in the JD store, it is expensive but it make the trick and I am sure it will work.
I bought my tractor about a month a go, I change the oil of the engine and filter, also I change the fuel filter, but I left behind the transmition for the future.
The filters I find in Chile are:
Oil : Mann W811/80
Air : Mann C1430 it is a little bigger in the outside diameter, the center diameter it is ok and the hight it seal good because is rubber and a beat high from the original
Fuel: Fleetguard FF5260
Thanks, .
Some one from the end of the world
   / What Oil/fluid should I use #10
i use 15w40 in all my gasser and diesels now.
and UTF meeting the manufacturers specs. wally-world or TSC generics / house brands usually do.
soundguy
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
