Oil & Fuel What oil do you use?
/ What oil do you use? #1
eatenabean
Alabama
MF 1643
I have a 2009 1643 and finally got 50 hours on it. The book said to use 10W-30.
I use Mobil 1 full synthetic in everything I have. Does anyone use this in their tractor?
/ What oil do you use? #2
With all the posts on lubricants why do you have to ask again?
/ What oil do you use? #4
I have a 2010 MF1643 and run Shell Rotella 5W40 synthetic in mine. I'm not sure if Mobil 1 10W30 is rated for diesel engines.
/ What oil do you use? #5
Yes, do a search and there is hours of reading.
If you want synthetic, most will suggest Rotella, or Amsiol. But it is best if you use an engine oil, that says DIESEL on the front of the bottle.
/ What oil do you use? #6
I am using Rotella 15w-40 in mine, 600 hrs no problems, did get down to -34f this winter, tractor is kept inside in a non-heated basement!
/ What oil do you use? #7
The man asked what kind of oil do you use, is that information to difficult for you to include with your post, :confused:?
I use Amsoil Synthetic Diesel SAE 10W-30W/SAE 30 Heavy-Duty Motor Oil.
KC :D:D:D
/ What oil do you use? #8
I use what the owners manual recommends as to weight/viscosity. Unless it calls for synthetic I use conventional oil, too many think synthetic conveys some magical properties that it doesn't. I have a 1998 dodge diesel with 377,000 miles that has had nothing but conventional shell rotella 15W-40, it runs and pulls like the day I bought it new. I have a 2006 diesel Jeep Liberty that does require synthetic so it gets shell rotella synthetic 5W-40. My 2006 Massey 471 gets Rotella 15W-40 conventional, same as the truck. As you can tell I like the shell rotella series of oils, I've had great service out of them. I don't have access to a MF1643 owner's manual but I'm a bit suprised it calls for 10W-30, I'd expect it to recommend 15W-40 with the 10W-30 as optional for a colder climate, which Alabama isn't. When in doubt I lean toward the heavier weight oil, I'm more worried about protecting my engine in the Mississippi heat than I am about saving fuel. Whatever you run make sure it's a C (for compression ignition) rated oil. I suspect your manual calls for a minimum of CH rating so make sure it's at least what's recommended. Mobil 1 10W-30 is only rated to CF from their website so it's probably not going to meet the requirements. Stick with oils from a major manufacturer with a good reputation, don't fall for the hyped sales pitch and pyramid marketing schemes of companies like Amsoil.
Hydraulic Braker Excavator Attachment (A64194)
Hydraulic Braker...
2015 WINSTON AP22024-DC 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
2022 Chevrolet Tahoe SUV (A64557)
2022 Chevrolet...
2025 Swict 84in Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
