Oil & Fuel What oil do you use in your Bota?
   / What oil do you use in your Bota? #22
shell rotella t 15w 40 in tracor ,lawn mower ,rototiller .
   / What oil do you use in your Bota? #23
Mystik JT-8 10W-30 synthetic blend (Services CI-4, CH-4, CG-4, CF-4,CF, SL, SJ, and SH).
I emailed Kubota and asked if Rotella T synthetic 5W-40 was OK to use since Kubota recomends 10W-30. The answer I got left me with little or no confidence in the knowledge behind the answer. "The Rotella was within the grade range they recomend and synthetics are fine just make sure they are marked API SL". The SL rating is for gasoline engines not diesels.:confused:
   / What oil do you use in your Bota? #24
Rotella 5-40 "synthetic". L4330, 200 hrs.
   / What oil do you use in your Bota? #25
I wondered a bit in the beginning...but since my B3030 is only a year old now..and the op's manual they sent with it specified oil that were "CD;CE or CF" spec'd...and the first two being OBSOLETE!??..I figured they cant be TOO particular about the oil going in them???
   / What oil do you use in your Bota? #26
Mobil Delvac-1 synthetic in all six of my diesels.
   / What oil do you use in your Bota? #27
Actually they are not obsolete. In fact, CD-II oil is still available for Detroit Diesel 2 stroke engines that require a low ash oil. It requires this older spec oil because the newer oils additive packages tend to clog up the exhaust ports in the cylinder walls which can cause hot spots and restricted exhaust flow.
   / What oil do you use in your Bota? #28
I suggest you go and download the latest API spec sheet! CD-II and even CE is considered "obsolete" by the API! CF2 is considered the newest replacement and substitute for CD-II
I never said they werent still MADE...now did I? And in my previous post..I never said anything about "CD-II"..I meantioned "CD" rated oil
   / What oil do you use in your Bota? #29
Mobil1 10W-30 Synthetic
Kubota brand japanese oil filters with the syntheic media. The little black ones.;)
   / What oil do you use in your Bota? #30
Same here. I've run Mobil1 in every engine I've owned for years. I use the Kubota filters only because I don't know what others might fit that are as good or better. IMO, oil is important... the filter is more important.
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
2024 Timpte 40ft Hopper (A55315)
2024 Timpte 40ft...
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
36 Volt Club Cart 4-Seater (A56859)
36 Volt Club Cart...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
