What? No position control stop on 5610 3pt
   / What? No position control stop on 5610 3pt #1
ruffdog
Super Star Member
southern wisconsin
Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
The 5610 has a real nice 3pt lift control lever and a height indicator out the rear window but no stop to set for height. When I'm using the 3pt rotary cutter and I get to the end of a row, I like to be able to raise the cutter, swing the turn, then drop the cutter without having to look backwards at the indicator. Tractors have a stop you can set on the 3pt lever, but not the Toolcat. So, I ordered a set of Mower Deck Height Stabilizer chains/brackets that I have seen used on old tractors. Here is a picture of them set up with just a draw bar so you can see how they look. The upper link would mount using the same pin that is used for the chain brackets.
   / What? No position control stop on 5610 3pt #2
Will the chain or upper bracket hit your PTO shield? Looks close in the photo. On mine, the chain/bracket definitely rests on the PTO shield when the 3 point hitch is lowered enough.
I'm not sure...I'll have to take a close look next time I use them. The main chain and bracket are slightly away from the shield when in use. I did zip-tie the loose ends to the other leg of the chain as they lay on the shield.
I mowed again and if you use the upper holes, the chains are not against the pto guard.
   / What? No position control stop on 5610 3pt #5
Tried it out, and yup, works like a charm. Thanx ruffdog.
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
7ft Fork Extensions (A55851)
7ft Fork...
Hercules Pesticide Applicator Tank with Nozzle (A55852)
Hercules Pesticide...
(16) 12" CHANNEL IRON (A57192)
(16) 12" CHANNEL...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
