What mower for YM 1510d?
   / What mower for YM 1510d? #11
Anybody know? Rotary, or flaiil, more easily damaged by rocks?
I very rarely hit a rock, only in a drainage ditch by the lane, and no damage so far in 15+ years.
What is others' experience?
I would have guessed that flail cutters are more easily damaged.
   / What mower for YM 1510d? #12
The flails bounce off of rock and are less likely to throw the rock. The cutting edges of any mower will be damaged by rock, but the flails have less energy eack and there are a lot more of them so cutting ability isn't harmed much at all. I wrapped some burried 1/2 inch cable around my flail and all that happened was a couple of bent knives, bit they straightened out easily. My flail is an older light duty Ford model so I don't use it in heavy brush. I have an old beater brush hog that I use to take out blackberries and other thick brush..
   / What mower for YM 1510d? #14
This is the swivel stump jumper blades on what I am calling a rotary mower. Tough as nails. RCR12 Series Rotary Cutters | Land Pride
First I run an older rotary cutter, and yes it tough and cuts most everything. That said, if it does not cut it and it is not solid in the ground, it can and it has thrown stuff. It has never happened to me, but I know a guy that thought he had been shot while brush cutting, but had a small piece if rock removed from his shoulder. He thinks that it hit a wall on an old barn and then was redirected to hit him. Wild set of angles, but he had photos of fresh marks on the wall. At any rate I have seen my through lots of stuff out.
I do not know his property layout, but I always insist that while I brush cut, everyone stats indoors or is not at home. My Iso-Tunes headphones means help is a voice activated call away.
   / What mower for YM 1510d? #15
Every 1510 we sold with a 48" Howse brush hog mower and an overrunning clutch.
You can always get chains for the mower to stop the flying missiles that you hit..... Be sure to walk the property first and look at the ground you will be mowing.
If you see any dangerous spots, mark them with some orange marking tape (loggers tape)
Dont use it without the overrunning clutch, you risk breaking the pto shaft, and your pride....
There aren't to many of those shafts floating around the US.
   / What mower for YM 1510d? #16
TractorErnie, great to see you here again. May just be me but I haven’t seen any comments in a while. Always great to get your very informed input.
   / What mower for YM 1510d? #17
Thank You for the kind words, I turned into a part time farmer in the south which keeps me real busy and then there's always the gran kids too....
   / What mower for YM 1510d? #18
How do you farm part time? There is always something to do when farming and it matters not what kind of farming.
I wish my grandchildren were closer. 2 about 90 minutes one way, the other a hard hard day away.
   / What mower for YM 1510d? #19
We farm fruit groves.
   / What mower for YM 1510d? #20
Well you got me on that one. I know next to nothing or perhaps less about fruit grove farming.
I have been involved with row crop farming and with a couple of different types of livestock farming.
At times in some of this while working a full time job in addition to farming. And a bit of haying also.
Between the various things needing to be done, I frequently worked as many or more hours farming as I did the other job. And always more hours at harvest time on crops. Even in off seasons there was plenty to keep one busy.
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2008 Dodge Ram 1500 Pickup Truck (A55973)
2008 Dodge Ram...
1996 Isuzu NPR Box Truck, VIN # 4KLB4B1R8TJ000333 (A57453)
1996 Isuzu NPR Box...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
ONAN 100DCDB GEN SET (A52708)
ONAN 100DCDB GEN...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
