what motor oil to run in a new TYM 554 with a yanmar turbo diesel
   / what motor oil to run in a new TYM 554 with a yanmar turbo diesel #1
sleepydeere
Woolwich, Maine
4052 R John Deere
Hi my new TYM oil says API CJ-4 grades API ACEA E-6 JASO PH-2 grade 0-30any info would be great thanks Mark
   / what motor oil to run in a new TYM 554 with a yanmar turbo diesel #2
I run this oil in my tractors Delo 400 XLE SAE 15W-40....... you can get it at wally world,,,
   / what motor oil to run in a new TYM 554 with a yanmar turbo diesel #3
I run Rotella T6 5W-40 in my red tractors. WW has it for about $22 a gallon. My 6530 uses all of the 2.5 gallon container (price advantage) and the 2400 makes out with 2 gallons.
   / what motor oil to run in a new TYM 554 with a yanmar turbo diesel #4
If the manual stipulates 0W-30 and gives the other specs as well that's what I'd run to maintain the warranty. Sometimes thicker than recommended oils don't flow as well and can cause problems.
   / what motor oil to run in a new TYM 554 with a yanmar turbo diesel #5
I'm using 5w30 Castrol in our 2 diesels after running it in our VW TDI for nearly 7 years with 10k changes. Since I'm now out of VW $, I plan to convert to 0w30 M1 ESP. Have found it online for a tad less than what VW charges for their diesel Castrol. The 0w30 would be even better than 5w30.
Ralph
   / what motor oil to run in a new TYM 554 with a yanmar turbo diesel #6
Here's a link for AMSOIL 5W30 Signature Series. It meets all the above requirements (I think you also meant JASO DH-2) except it's not 0W30 but a 5W30. Pours down to -45F, so good for those Maine winters. Click on link then Technical Specs and then Data specs for more info. Comes right to your door with Free shipping this month. Last day is Tuesday... I'm ordering some stuff tomorrow. Signature Series Max-Duty Synthetic Diesel Oil 5W-3 DHD - AMSOIL
Dutchy
   / what motor oil to run in a new TYM 554 with a yanmar turbo diesel #7
You need 0w30 for cold starts in Maine. Otherwise, the top end will starve for lubrication for a few seconds until the oil pump gets suction.
Ralph
thanks for the info I had purchased the Tym but the dealer was dishonest and I ended up with a new John Deere 4052R with the backhoe and thumb
   / what motor oil to run in a new TYM 554 with a yanmar turbo diesel #9
Tell us the story. It sounds interesting...
Dutchy
Dutchy
Hi we had purchased the tractor at one location and the tractor was at the other location,we went and purchased the backhoe and thumb,and a set of titan 5500pound forks we payed cash for the forks and some on the backhoe aso 15000.00 down payment and fianced the rest. this was the 6TH of the month.they said they had to order the backhoe and thumb, we said ok. I had asked for pic of the forks 2 times with no reply, I asked the guy we purchased the tractor from the for pic of the forks and said that I was worried abt service. my tractor was still listed on e-bay after I had purchased it I knew which one it was because it was a shuttle shift and it had the 3 scv on the loader. I had looked on facebook market place and see my forks I had purchased,they were still listed, so we went up with a trailer 3 days after we bought them,i didn't take them when we purchased them because we didn't have tie downs with us.so we get there he looks for the forks and they are gone , he said another salesman sold them,and you culd have the other set, I said no I want the ones I payed you for. he said I will order you another set.so now we at the end of the month no backhoe and thumb, he said that the backhoe was going to have the thumb on it.he said that the backhoe was there and no thumb and no forks, it was days later and called to see if it was done, he gave me a hard time I said if I gave you a bad check the sheriff would be at my house,i said that was the same thing he did with the forks.then the head one called me ,I said the deal is off I want my money back, it was over a week before we was refunded. and a lot more had happened also. let me know what you think of that Mark
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
Tradewinds Power Unit (A50120)
Tradewinds Power...
