What models with a BT-751 Hoe fit?
   / What models with a BT-751 Hoe fit? #1
Stokes
Kitsap Peninsula, WA
It came off a B21. Were these just slightly too weird to fit any of the other machines?
   / What models with a BT-751 Hoe fit? #2
Yes they were specifically set up for the B-21. It would be dificult to install the subframe on any other tractor.The subframe runs from the back up to the clutch housing/engine where it becomes part of the loader subframe. The B-21 also has an additional hyd. tank mounted under the tractor to help with cooling. You may be able to install the BT-751 on the B-20 which is the older B-21 model but I have never tried it.
J.D.
UNUSED JCT 96" SNOW PUSHER (A54757)
UNUSED JCT 96"...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
UNUSED FUTURE MINI QUICK ATTACH PLATE (A54757)
UNUSED FUTURE MINI...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
