Tractor Sizing What model?
   / What model? #1
hddm3
indiana
allis 170
Hi guys, what model would you guys recommend for a 60acre farm. My farm is hilly, so keep that in mind. I would like an all around tractor. I want a backhoe att to fix broken tiles, plow, plant and bail my hay. This will be my first jd. Im almost dead set on jd, but ill let your knowledge guide me. Thanks so much for taking the time to read this. Take care.:thumbsup:
   / What model? #2
Welcome to the forum.
Your decision will need to include the equipment you plan to get for baling (small square, large square, round) and plowing (all 60 acres?). But a 60 - 100 hp tractor should cover most tasks.
Just wondering if you want to try doing everything with just one tractor, or have a couple around to aid in sharing equipment. Like the backhoe on a small 40 hp tractor that doesn't have to be removed when the haying needs to be done.
   / What model?
I would like to have just one for all. Round bailler. I do everything myself. Ill be buying all or most att used. Im not opposed to buying a used tractor either. 45acres plow, and 15acres grass. thanks guy
   / What model?
ok thanks guys. Take care.
   / What model? #5
smallest I would go is a 4520. the 4520 may be to light for the baler from a size/weight point though. I would think that the 5000 series would be better. Somewhere around 75hp is where I would begin to look.
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
(3) Ironman Tires (A50121)
(3) Ironman Tires...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2007 Chevrolet WA4500 Box Truck (A50323)
2007 Chevrolet...
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
