What Model Ford is This?
   / What Model Ford is This? #11
I can see why it wouldn't run if you gapped between the flat on the distribuitor cam and the rubbing block.
Good job on getting it running. Now that it is running.. you can swap those wet plugs back in one at a time and they will be fine.
soundguy
   / What Model Ford is This? #12
Hey Dan, I'm the original owner of a 1956 Ford 850 and I can assure you that tractor is small but a brute in disguise. (I have the HD segmented wheel weights on mine which really help it make use of that nearly 50 horse engine) Mine is totally stock except that I installed a 6 volt solid state module in the distributor in place of the points. The points would oxidize if the tractor sat for an extended period of time-a fantastic improvement for under a $100 bucks. You've been given some good advice on this forum so while I know this tractor like the back of my hand I leave well enough alone. Enjoy it and USE it. Post a picture sometime.
KBH 25T Tender (A56438)
KBH 25T Tender...
Craftsman Tool Box on Wheels (A57454)
Craftsman Tool Box...
Aluminum Deer (A57454)
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
