What material does a weld not stick to?
   / What material does a weld not stick to? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Still unable to post a picture so try to visualize. I'm building a light duty cultivator and have some 2" x 2" equal angle iron that's 3/8" thick and 7 ft long. It has a line of 3/8" holes punched an inch apart the length of it. The problem is, the guy that got these first had other ideas and cut the pieces in half. :eek: Then he re-welded them but got the pieces crooked and I need to start over.
My plan is to cut them in half again on the weld and then weld again but get things straight. Since I need to get the holes spaced correctly I plan to use a short length of the same stock that I have and bolt the two pieces to this. It will assure the holes will line up plus will stay flat as I weld it.
The question is, what can I put between the pieces to keep any weld from sticking to the spacing piece? Is it copper, brass aluminum or all of them? Since the surface will be tight together, a thin sheet would do it. I've never done this.
Also, since I'm bolting the two halves to the spacing piece, can I just weld one side and then flip it over or will the heat try to warp it and should I do something different?
   / What material does a weld not stick to? #2
I have some 1/4" x 4" copper electrical buss bar that I use for jobs like this. I have some aluminium bar as well but always grab the copper. It carries the heat away and normal 6011, 7014, etc won't stick to it.
Can you shorten them by 1" to get a nice square end when you cut the old weld out? This would still keep the 1" spacing...
   / What material does a weld not stick to? #3
It would be better to use spacers so your weld is away from the backing piece. Ed
Yes, I could cut it square. Am going to MIG weld it.
How thick of a spacer? I like that idea better.
   / What material does a weld not stick to? #5
I try to keep the weld tight to the copper so it removes the heat and gives a flat surface to the steel where it meets the copper. If you use spacers then you could use a steel backing plate then grind it smooth...
   / What material does a weld not stick to? #6
Steel weld won't stick to aluminum. I've made welding fixtures from alum and the welding splatter doesn't stick to it.
   / What material does a weld not stick to? #7
Copper works very well. Use it all the time filling in old bolt holes or pin holes that are wore out so I can re-drill them.
I don't like aluminum. Mig weld will stick to it, and it will melt and just be an ugly mess.
   / What material does a weld not stick to? #9
How thick of a spacer? I like that idea better.[/QUOTE]
Almost anything, 1/4" would work fine, just needs to be thick enough to give you some space. Ed
   / What material does a weld not stick to? #10
Keeping it straight will be the challenge. How much tolerance do you have?
2013 Dodge Grand Caravan SE Van (A42744)
2013 Dodge Grand...
2020 KENWORTH T800 T/A DUMP TRUCK (A45333)
2020 KENWORTH T800...
1995 TRANSCRAFT 45’X96” FLATBED (A45046)
1995 TRANSCRAFT...
MISC PALLET (A45333)
40ft 5 Dual Door Shipping Container (A44571)
40ft 5 Dual Door...
2009 Western Star Trucks 4900 FA Truck, VIN # 5KJJAEAV19PAH6101 (A44391)
2009 Western Star...
