What liquid expands the most with a temperature change?
   / What liquid expands the most with a temperature change? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I can't go into the details of the project but basically I intend to fill the bottom side only of a "hydraulic" cylinder with a yet to be determined fluid. What is going to provide the most movement of the cylinder with a temperature change? Just looking at a couple of charts that I have no idea what they actually mean maybe Ammonia.
   / What liquid expands the most with a temperature change? #2
There are more complications to this than appears on the surface. Ammonia is nasty to work with and needs to be under a high pressure to remain liquid. Any gas off the liquid will be compressible so will not move the push rod. The seals on a hydro cylinder will probably not be compatible with a lot of fluids, especially like ammonia. Think Teflon seals. A lot of research on temp/press relationships and hydro calcs are in your toolbox for this. You will be dealing with more than one liquid/gas physics laws. My arm chair engineering at work.
Ron
I've already thought about at least the corrosive part. The possible solution was to use an expansion tank. Put the expanding liquid in the rubber bladder and put put oil in the other side. Then it expands and forces oil out of the cylinder into the tank.
   / What liquid expands the most with a temperature change? #4
I suppose a pertinent question is what are you trying to accomplish? Detect a temperature change? Move something heavy (or light) based on temperature? Something else?
Have you ruled out electronic sensors and actuators?
I'm trying to move something light based upon a temperature change. Electric isn't an option.
   / What liquid expands the most with a temperature change? #6
Remember that many liquids don't expand at a regular rate. That is, they don't expand proportionally to temperature changes. Mercury in a thermometer expands very regularly through a broad temperature change. So keep that in mind for your project X.
Also, you can't compress a liquid, so if its under pressure, it won't move much. Release the pressure and woosh!
   / What liquid expands the most with a temperature change? #7
Have you thought about using metal like a thermostat?
I probably need 10 pounds of push and 3 inches of travel. I don't think the metal could accomplish it.
   / What liquid expands the most with a temperature change? #9
I hope you share the project once its done.... sounds interesting. :thumbsup:
   / What liquid expands the most with a temperature change? #10
Greenhouse vent cylinders.
Automatic Greenhouse Vent Openers & Circulation Fans
How automatic vent openers work: Vent openers do not require electricity. The opener has a metal cylinder containing a mineral which expands when heated. This pushes a piston that opens the vent. As the temperature cools, the mineral shrinks and a spring closes the vent and resets the piston. The opening and closing of the vent is gradual allowing just the right amount of air flow for cooling.
and
Greenhouse Accessories : Univent Automatic Vent Opener Replacement Cylinder
Use the Standard Vent Opener to lift up to 15 lbs, and the much stronger Gigavent, with powder-coated green, all metal construction, to lift up to 65 lbs.
Bruce
PALLET OF IRRIGATION PUMPS / WATER PUMPS (A51244)
PALLET OF...
JLG SKY TRAK (A50322)
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2022 CATERPILLAR 272D3 WHEELED SKID STEER (A51242)
2022 CATERPILLAR...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
2009 FORD E-350 VAN (A50324)
2009 FORD E-350...
