Comparison What kind of Mitsubishi Tractor do I have?
   / What kind of Mitsubishi Tractor do I have? #1
dangerdave865
Brandon, Vermont
Mitsubishi
I recently purchased a Mitsubishi Tractor. It needs some work, but I can't find parts for it because I have no idea what kind of tractor it is. All I know is that it is a 4 X 2 diesel inline 4 cylinder with low, mid and high range and 3 speeds plus reverse in each and a locking rear end. It also has 9.5-24 tires on the rear It has been re-painted several times and the usual plates and such are heavily painted over. All I can find is what I would assume are part numbers on some of the castings and engine block.
They are:
M79-11545 located to the right and on the side of the gear selector
6957206000 & 81030 located under the driver seat
1901121 located on the exact opposite side as the other gear selector number
T00109 located on the rear axle tube
9X14 located on the engine block just above the dip stick
I hope that this info helps someone help me figure out what this thing is.
Thanks in advance!
   / What kind of Mitsubishi Tractor do I have? #2
I think I'd clean off the plates to be sure. Anything else would be an educated guess at best.
I can try, but the paint that is on it is some kind of enamel and I didn't want to damage what is there when I take it off. However the thought had crossed my mind so maybe I will go give it a try real quick.
Ok so the best I could do is this...it says M and then I think it was a T then a 2 then maybe a 0, the next number is gone and the last is a 0 so to sum it up
M then T? 2 0? * 0
   / What kind of Mitsubishi Tractor do I have? #5
Try looking at this web page. You may be able to tease it apart with pictures/descriptions. Valley Power
So I have been to this site and looked over it a lot. From what I can tell by the pictures it is a D 2350 or a D 1650 but the numbers that I CAN read would indicate otherwise.
Is there any way that I can use the numbers I stated above in my original post to help narrow it down?
   / What kind of Mitsubishi Tractor do I have? #7
did you try this portion on that web site? look at the end of page 3 and start of pg 4.
Valley Power
OK so I went to change the oil on this thing and I found another number on the engine which is K4C and a 1.200L marking. Referencing the Valley Power site this means that it is either a D 2050, ST 2020, or a ST2320. Since the drivetrain is 4X2 I assume it is not a D 2050. I don't see a picture of a ST 2020 so it must be a ST 2320.
Thanks for the help so far guys! Now a new question. Where can I find parts for this thing? I feel confident making my own gaskets and such, but I may need other stuff and it seems almost impossible to find these things, even on the internet.
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2014 FREIGHTLINER...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED (A54607)
2025 GREAT DANE...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
