dangerdave865
I recently purchased a Mitsubishi Tractor. It needs some work, but I can't find parts for it because I have no idea what kind of tractor it is. All I know is that it is a 4 X 2 diesel inline 4 cylinder with low, mid and high range and 3 speeds plus reverse in each and a locking rear end. It also has 9.5-24 tires on the rear It has been re-painted several times and the usual plates and such are heavily painted over. All I can find is what I would assume are part numbers on some of the castings and engine block.
They are:
M79-11545 located to the right and on the side of the gear selector
6957206000 & 81030 located under the driver seat
1901121 located on the exact opposite side as the other gear selector number
T00109 located on the rear axle tube
9X14 located on the engine block just above the dip stick
I hope that this info helps someone help me figure out what this thing is.
Thanks in advance!
They are:
Thanks in advance!
