What kind of hydraulic flow restrictors do I need?
   / What kind of hydraulic flow restrictors do I need? #31
I had considered them for running my 8gpm hoe on a 23gpm circuit, but was advised not to on similar grounds to Banjo's post, besides needing one for each function would have been 12 restrictors I think. (Not so cheap for that application) I went with adjustable 0-16gpm press compensated flow divider that takes what hoe needs from flow and sends rest to tank.
   / What kind of hydraulic flow restrictors do I need? #32
MMM,
how's the pressure compensated flow divider for heat in that application? Unless I've got it wrong, isn't all the extra 15GPM times whatever PSI is needed at that moment converted to heat?
Rotary flow dividers are well worth looking into. They're not adjustable, but they're very efficient. Once I got my mind around how they work, I became a big fan of them.
   / What kind of hydraulic flow restrictors do I need? #33
This system is on a crank drive front pump that I installed with industrial loader. I installed 24X12 cooler and pair of Sun Hyd flow dividers for dual aux hydraulics. I had looked into rotary dividers, but there is a problem with pressure intensificvation and the adjustability isn't there.
   / What kind of hydraulic flow restrictors do I need? #34
</font><font color="blue" class="small">( Henro, et.al.,
I think it turns out that this might be a bit of a case of the fingers being faster than the brain /forums/images/graemlins/blush.gif.
You can get cavitation in the supply line if you have a flow restricter there, AND the cylinder is being driven by an external load (as would happen in lowering a loader with a load on it for example). In this case the fluid can exit the system faster than it can be supplied. It's hard to figure out how this situation would occur for a set of grapples though.
A similar situation can occur with hydraulic motors if they end up running as a pump due to an external load (e.g. flywheel loads, braking with wheel motors).
Managing the return flow addresses these issues. FWIW, I think of it as making the cylinder "look" like it's under a heavier load.
I found a number of references to "smoother" control with the "one way" type of valves in the return path. This would be consistent with the above information, where the system might work like it had "air" in it.
The "brain surgery" comment is well placed too. The "right" solution take a lot of factors into account. It'll be interesting to hear how the simple solution works out in practice.
I should also mention, that I haven't had the need (chance) to use any of these valves in the hydraulics that I've done to date (loader and backhoe), so I was just going from (recollected ... always hazardous /forums/images/graemlins/grin.gif) experience from others, and from my efforts to "figure out" hydraulics. I'm no expert, and sometimes having an engineering background can work against you /forums/images/graemlins/wink.gif.
HTH, and sorry for any mis-information. Andrew )</font>
I had you figured out on the first message, but I see you got back to it.
If the flow restrictor is on the high pressure supply side only, you sort of turn the cylinder into a one-way cylinder at times. Any time you allow the cylinder to move, oil can flow away from one side rapidly, while you are supplying oil very slowly to the other side. This will allow the cylinder to draw a vaccumn & fully extend if it has enough load on it, but will take a long time for the oil to build up on the other side of the cylinder.
It would indeed act like there is air in the system under certain conditions. One would have less positive control of the situation. You effectively have a 1/2 hose supplying oil to or from one side of the cylinfer, & a 1/16" hose supplying oil to or from the other side. That's unbalanced...
May not be important in a grapple.
And it would not cause damage, it just might, possibly, in some uses, cause a feeling that one isn't in control of what is happening all the time - extra slap or bounce on the controls.
As someone else said, this is brain surgery analysis, go ahead & hammer it together & have fun. /forums/images/graemlins/smile.gif
--->Paul
   / What kind of hydraulic flow restrictors do I need? #35
adlertom
How did the pin-hole restrictor work? Did you get satisfactory flow control using it?
Hopefully we can find out the results. /forums/images/graemlins/wink.gif
   / What kind of hydraulic flow restrictors do I need? #36
Tom, I hve been following this thread and am wondering why no one has mentioned, you don't have to push or pull the control handle all the way.That is the way to control how fast the graple opens or closes. At least thats how I operate mine.Yoy will get better with practice. Ron
   / What kind of hydraulic flow restrictors do I need? #37
I use adjustable (one way)flow restrictors when I want controllable top speed one way and a full speed return. I use a single needle valve when I want to control (slow down)top speed in both directions and yes one direction will be slightly faster than the other(due to the fluid displaced by the cylinder rod). If I wanted to accurately control speed in both directions I would install two adjustable flow valves one for each direction. This has worked well for me in multiple applications. AS FOR CAVITATION ,HEAT ISSIES etc. I don't worry too much about turbulence at 30000 ft when for my usage my tractor barely leaves the runway.
Drussell--- Grand L 4240 cab 950 hrs- 854 loader with 3rd fuction control -4 way HD bucket - TnT- Hydraulic rear and front blades- 6 ft front snow blower with hyd controls.
   / What kind of hydraulic flow restrictors do I need? #38
Welcome to TBN Ron:D
You have been following this thread? Since 2005? And now just replied?:confused2:
Just bustin' chops...welcome again.
   / What kind of hydraulic flow restrictors do I need? #39
All - I know this is an old tread and I made a posting yesterday without doing a very good search - sorry! My posting was in regarding a new grapple attachment for my Bobcat S160 and what I could do to slow the grapple movement down. Now that I've have found this thread, can anyone tell me if Tractor Supply has the type of in-line flow restrictors that might help me? It seems that I need one restrictor in each hose and if I get the simple "pin-hole" restrictor and it's reduces the flow too much then I can just drill it out a little. This seems like a "cheap" - "simple" fix for a frustrating problem.
   / What kind of hydraulic flow restrictors do I need? #40
That little washer type restrictor is the cheapest way to go.
I am not sure TSC has them, but maybe. Maybe a local hyd shop or order off the Internet.
They might have something like this, a fitting restrictor.
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
16ft T/A Flatbed Trailer (A56858)
16ft T/A Flatbed...
2015 FREIGHTLINER M2 26FT BOX TRUCK (A58017)
2015 FREIGHTLINER...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
