What kind of hook is this?
   / What kind of hook is this? #11
The hay hooks I have seen are made from rods not flat stock.
The hay fork I have is made from flat stock actually. That said, the overwhelming majority of them seem to be made from round stock. Probably runs in and out of the hay easier.
   / What kind of hook is this? #12
A way to make scrap material into saleable items.
The hay idea is a good one, as there is plenty of haying around here. There were plenty of these made of round stock there, in addition to flat stock. Some had a mass produced look to them, and there were some that seemed identical and some that were different in minor ways, so I think it must be (or must have been) a somewhat common item made by multiple manufacturers.
Here's an example of what I see when I google "grappling hay hook" (not necessarily in that order):
The things I'm finding online seem to share the size and construction of what I bought. All are obviously for taking a big grab of something not very dense, such as hay. The online examples also have that little ring, apparently to open a grappling assembly.
However, my shape isn't right for this. The online ones are curved on a radius around the eye, so they'd travel cleanly into the hay as they pivot about the eye. Mine is curved around a point far from the eye, and if you wanted it to cleanly penetrate, you'd have to swing the eye backwards.
There's also plenty of tobacco grown around here, and it would be a light bulky product. Could this be for tobacco?
The best bet so far seems to be what I found here, which they're calling an "antique scaffolding hook", and I've found a few other references to that. However, they often put a question mark on it, so apparently not sure.
   / What kind of hook is this? #15
What is this hook intended for? I bought it from a junk and curiosity dealer in Oxford PA who had a bunch of them. It's steel, and seems fabricated from half inch by two inch steel bent the hard way, except I can't tell how they formed the eye. Except for a little bit in the eye, I don't see any wear, only weathering.
He said it's for holding things that are spinning. You hang them in the hook and they slow down. That's why there's a small ring attached on the outer bottom. I have no idea what he's talking about.
Thanks!
Hay bail hook for moving bails into hay loft. My brother-in-law has one that is 1" dia round stock.
   / What kind of hook is this? #17
Maybe its from a slaughter house or meat processing plant?
   / What kind of hook is this? #18
That little hook on the bottom is for you to hang it on a nail in the wall and call it art.
   / What kind of hook is this? #20
I think we may have a winner!
2017 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A56858)
2017 International...
2372 (A58376)
2372 (A58376)
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58216)
2018 PJ TRAILER...
(NEW) 2022 Greenworks CU400W Commercial Work Utility Vehicle (A56436)
(NEW) 2022...
2827 (A58376)
2827 (A58376)
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
