What kind of finish on pine?
   / What kind of finish on pine? #1
Tdog
Platinum Member
SE Louisiana
BX22
My wife wanted a storage box to keep on the front porch. I built the box in the photo out of tongue & groove pine. I'm almost finished - - I need to gussy it up a little. I'll add handles on the top, & maybe some corner molding for the edges. It is heavy as the dickins - - glad I have a FEL.
The box will be on a 10' x 60' porch, so it will be outside, but only minimally exposed to the elements. I had planned just to put a tung oil finish on it. I was pretty ignorant about what I expected, I guess. When I use that treatment on mahogany, it turns it to a richer, darker finish. When I tried it on a sample piece, it doesn't do much at all for the pine. Not sure what I want here - - just wasn't expecting it to stay so blond.
Any suggestions?
Thanks,
Jack
   / What kind of finish on pine? #2
Put some stain on it and topcoat with urethane.
   / What kind of finish on pine? #3
Pine in my opinion is a tough wood to get to stain the right color. I think that it is due to the soft wood. I have good luck outside or in a wet area with mix of turpentine and boiled linseed oil after stain.
   / What kind of finish on pine? #4
ANut is right, pine doesn't take stain well.
If you absolutely must stain it, get a highly pigmented stain, and do your wipe off lightly.
Personally, I would accept the nature of the wood and work with it. Spar varnish will make it a bit more golden than blonde and protect it from moisture.
   / What kind of finish on pine? #5
you could try some exterior semi-transparent stain.
   / What kind of finish on pine? #6
I agree.. Or use the minwax stain+urethane all in one.
Soundguy
Thanks all. Still not sure what I'll do. At least I've got lots of scrap to try different finishes.
Jack
   / What kind of finish on pine? #8
It sort of depends on what color you are looking for.. a warm yellow can be had from shellac with poly over. A darker (more brown) yellow can be had from water based stain, poly, shellac, poly. With some experimenting a dull brown can be had from water based stain & poly (cherryish red also). Milk paint is always a rustic alternative :)
   / What kind of finish on pine? #9
We have all pine trim in our new house. Pine will take a dark stain pretty well but a light stain not too well. After experimenting we settled on cherry stain and really like the results.
   / What kind of finish on pine? #10
Depending on what color light or dark you want to end up with maybe you will not need any stain. Pine that has no stain will turn a honey color after a while. I made a screen door out of pine that has taken on a nice mellow honey color. I have also used cherry stain on pine with nice results, just a little darker with a reddish brown hue.
As far as an outside finish I always use a marine grade finish. This seems to stand up better to wet conditions and has UV protection from the sunlight. That is a nice looking box.
Randy
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2022 BOBCAT T595 SKID STEER (A52705)
2022 BOBCAT T595...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2014 Haulmark Box Trailer (TITLE) (A50775)
2014 Haulmark Box...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2008 Ford Focus Sedan (A55758)
2008 Ford Focus...
