What kind of chain?
   / What kind of chain? #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
:DHi everyone,
Just bought a JD 4320. I was wondering what size chain and what grade does everyone use to pull and lift with?
Thanks
Dave
   / What kind of chain? #2
For securing the tractor to a trailer Grade 70 is recommended. Just make sure the chain (WLL) working load limit exceeds the item being secured.
For general pulling and lifting I use 3/8" grade 43. The chain WLL exceeds what my tractor will pull or lift.
   / What kind of chain? #3
Personally I like wire rope. Its far cheaper and much, much lighter for the same working strength.
As an example...
Wire rope
Chain
If you assume 1/2 diameter 6x19 class IWRC vs grade 70 chain...
Wire rope: 26,000 break strength, .46 lb/ft, $1.29/ft
Chain : 13,000 break strength, 2.4 lb/ft, $6.28/ft
The advantages add up pretty quickly. Obviously you need to size the cable to YOUR application but when you look at price and weight I think the advantage of wire rope is pretty clear.
My opinion.
Wire rope is very unhandy to use pulse it will fray.
Thanks for the input.
Dave
   / What kind of chain? #5
I also agree grade 70 would be 1 of your best choices but it will also suck the $$$ out of the ole safe.
I bought 3/8 43 grade from HF on sale great deal I felt. I have yet to break it even when I pull with the dozer.
   / What kind of chain? #6
try a semi truck or trailer dealer parts dept. for your chain,they are usually alot cheaper than a hardware store or tractor supply. i bought 3 grade70 20 ft. chains with hooks for $40.00 apiece last fall from truckpro.
   / What kind of chain? #7
Wire rope won't last anywhere near the life of chain.
kj
   / What kind of chain? #8
Grade 70 would be the best for pulling and lifting. I can see wire rope for pulling maybe but using it to lift with would be a pain in the but IMHO. With a chain you can adjust the length easily but with wire rope you are stuck with one length.
   / What kind of chain? #9
Get my fill of cable skidding wood. Chain is the way to go.
5/16 gr 70 transport chain is good all around, 4 of them on a tractor is enough for your JD. If you have a loader DOT will require 4 chains on the machine and 1 chain on any additional boom and or extention. Meaning 6 chains and binders on a tractor with loader and implement on back, overkill but its the law. These 6 chains can be quite short if the tiedowns are positioned correctly. We have 4 footers for the tractor and 10 footers for the implements.
I use those for pulling and hauling as well, I also have a 8' 3/8" gr43 chain I keep right on the tractor all the time to save me running to the trailer all the time, comes in handy. I don't even know where that one came from.
   / What kind of chain? #10
Actually, as long as the machine is under 10,000 lbs you need only 2 grade 70 3/8" chains on it, and one for each implement attached to the tractor.
If it's over 10,000 lbs, 4 grade 70 3/8" chains are required as well as one on each attachment.
The 10,000 lb. is the key here, changes the rules dramatically.
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
ALUMINUM WHEELS AND TIRES (A53843)
ALUMINUM WHEELS...
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
2011 WESTERN STAR 4900 (A53843)
2011 WESTERN STAR...
kids dirt bike (A53424)
kids dirt bike...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
