Box Scraper What kind of box blade is this thing?!?
   / What kind of box blade is this thing?!? #51
I never measured it that way. Itç—´ 73 long
I値l see if I can get the other measurements tonight!
73 inches would be the width.
My 6' wide is heaver than the 8' wide.
6' __________________________________ 8':
   / What kind of box blade is this thing?!? #52
I just got around to weighing this box blade. Would anyone like to take a guess on how much it weighs before I post. I used a crane scale to get to the exact pound
My guess is 850 pounds.
Thanks for your guess! And to answer your question it is 31 wide
   / What kind of box blade is this thing?!? #54
I have no idea so I'm going to guess just under 500 lbs.... Call it 490. And thanks for the fun.
rscotty
   / What kind of box blade is this thing?!? #55
Looks like you are confused on the way box blades are measured.
Yours is 73 inches side to side, that is the width.
And 31 inches front to back, that is the length.
And since it is a little bigger than I thought, I am going to increase my guess to 950 pounds.
Not many participants but Xfaxman for the win with a very close guess of 950! Only 8% off
Total weight came in at 1035.5 (took one scarifier off so probably another 10 lbs)
Weighed it with a crane scale and a chain hoist. I made a vid if you want to check it out. Just skip toward the end. I weighed my bucket and forks so you can just skip that Unless you want to know what a kioti 72 bucket weighs
Thanks for playing
How to weigh your tractor implements - YouTube
   / What kind of box blade is this thing?!? #58
Your crane scale should have a button to zero the reading after you hang the chain hoist and chains.
On mine it is labeled "Tare":
Yes it does. I talked about it in the video a little bit but just went with the math. Your scale is very nice. How much do your boxes weigh
   / What kind of box blade is this thing?!? #60
The 6' is 647 pounds:
The 8' is lighter at 638 pounds:
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
