What Kind of Attachment is This
   / What Kind of Attachment is This #1
WHarris
Slapout, AL
Ford
I recently bought some land and the previous owners left what I believe is an old field cultivator. They said I could do whatever I wanted with it, so I need to know it's worth anything more than scrap metal. I can't post pictures right now but I could text them. It's at least 10' wide and 10' in length. It has a long hitch arm with a ring type hitch. It has two rotary type tiller looking deals on the back and the shaft is broken on one of those. It has some kind of hydraulic lift on the front half. It's old and rusty and the tires are flat. I believe it was originally painted Yellow. Other than cutting it up for scrap, I don't know what I could do with it?
   / What Kind of Attachment is This #2
Sounds like a do-all maybe?
Back when everything was planted up on hipped up (aka bedded) rows.
After pulling up rows and before planting you pulled a do all over them and it flattened out the top of the row and broke up the clods.
It is useful to on a field that has been disked as well to break up the clods and give you a good surface to plant in.
   / What Kind of Attachment is This #3
20150426_153328.jpg Does it look anything like this?
   / What Kind of Attachment is This #4
----------- I can't post pictures right now but I could text them. --------
Download the TBN app and you can post pictures from your phone.
View attachment 439645 Does it look anything like this?
Yes, it is very similar to that. I went back out and looked at it again and it has two hydraulic pumps on it. It's a very heavy duty attachment. I hate to cut it up for scrap if anyone could use it. I'll try to post some pictures and just let someone have it if they will come get it. Thanks
   / What Kind of Attachment is This #7
old spring tooth rolling harrow used to finish a field before planting. Looks like it been robbed pretty good. Its worth more than scrap IMO lots of good steel to be used for projects.
Thanks for the info. I figured somebody who knows what they are doing might be able to use it for parts or convert it to something else useable. I really just want to get it out of my way and cutting it up for scrap metal would be a lot of work! :)
   / What Kind of Attachment is This #9
if I was closer I would come get it. 2.5 hrs from work and 3 .5 from home is a little far to travel for scrap. I will check around I know a few folks up that way that might be interested.
   / What Kind of Attachment is This #10
That looks like it would be perfect base for a a grader type attachment.
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
