What kind\grade hydraulic fliud to use
   / What kind\grade hydraulic fliud to use #1
Kenfranklinl
massachusetts
ford 1200
Hi everyone. Can someone tell me what kind\grade hyraulic fliud I should use for my Yanmar 66o 3pt backhoe. I was given some hydraulic fliud that had water in it now I have to drain the tank and but in new oil. Thank god I did not start it up.
   / What kind\grade hydraulic fliud to use #2
Ken,
Nobody paying attention to you..??....I thought you'd be inundated with responses.....:laughing:
Not sure what hyd system you have....?? PTO Pump and separate reservoir..??...Any good AW-32 hyd oil or tractor/trans fluid would work (as long as it doesn't have water in it....:thumbsup:)
   / What kind\grade hydraulic fliud to use #3
Unless the water has been emulsified with the hyd fluid, I would suspect it was on the bottom of the container, or reservoir/tank. Once it goes through the pump and several cycles, it would be emulsified.
Thanks Bill, Ya its a PTO with resevoir. I got the oil from my brother who has been a heavy equipment operator for about 45 years. the 5 gallon container got water in it some how and i did not notice it until I pumped about a gallon in.
The Piston you rebiult for me looked great and went together nice and easy.
Thanks for your help again, Ken
   / What kind\grade hydraulic fliud to use #5
Thought you might find this interesting while I was doing a google search on your Yanmar....
Yahoo! Groups
This could have been you......:laughing:
Yea, those PTO Gear pumps can handle any good quality hyd oil .....doesn't have to be the super premium stuff......
Ya, I found that also today. But not much of any info out there on the 660. Thats why this forum is so great because of the knowlege of the members.
   / What kind\grade hydraulic fliud to use #7
utf fluid is likely fine..
soundguy
MILLER SYNCROWAVE 351 TIG WELDER (A52472)
MILLER SYNCROWAVE...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2012 AMERITRAIL, INC. 30 T/A GOOSENECK TRAILER (A52472)
2012 AMERITRAIL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
