What is your average fuel consumption per hour?
   / What is your average fuel consumption per hour? #1
CEPGEO
Taylorsville, KY
2013 Mahindra 3016 SST
Was wondering what everyone averages for fuel consumption per hour operated? I know it depends on use, which is why I was asking for an average. My tractor averages about a gallon of diesel per hour...was just wondering if that was typical.
   / What is your average fuel consumption per hour? #2
I have a Jinma 554 that is usually pretty good with fuel consumption. However, when using my snow blower I need to keep the revs up around the 2400rpm range and at that speed I use around one gallon an hour. When using the blower the snow is usually 6" or greater in the drifted areas, so the engine is working pretty hard at times.
Jim
   / What is your average fuel consumption per hour? #4
I want to say about a gallon an hour with my Bobcat CT230. A lot depends on temperature, RPMs I'm running at, and load.
   / What is your average fuel consumption per hour? #5
On my B2920 it's just under 1 gall / hour at PTO speed (probably like .9 or .8). At lower RPMS its a lot less....
   / What is your average fuel consumption per hour? #7
1 to 1.5 for my Kubota l45 after a big day the fuel lights on and I have to put 2 5 gallons
   / What is your average fuel consumption per hour? #8
I had to look this up and saw that the tractor only hold 11.2 gallons, only then did I realize the you were putting in 2 each 5 gallon cans (10 Gallons) and not 25gallons.
   / What is your average fuel consumption per hour? #10
I also have similar experience with the CT235. I usually run 5 hours at 5.5 gallons.
MoKelly
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2013 FORD F-350 (A53843)
2013 FORD F-350...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
Toro Mower (A50324)
Toro Mower (A50324)
