What is with impliment makers?
   / What is with impliment makers? #1
TheMan419
Veteran Member
Indiana
New Holland Boomer 24
I am looking at a couple of tillers. I cannot find anything acceptable used at a price that makes sense to not buy new.
So looking at new ones. Most of them on line have a copy of the manual. I look at those to determine what else I need to get (i.e. one of them needs a 1 1/4 wrench/socket which I don't have).
What gets me is they all specify to "fill gear box with xxx oil" (xxx being the type of oil they want). NONE of them tell me the QUANTITY that I need. Just fill it up to a certain point. No guidance is that a quart, 4 gallons.... what is it?
Arrgh.
Sorry. Rant over.
   / What is with impliment makers? #2
Takes a gallon for the 72" TSC tiller I bought a couple of months ago for $2k. Does the PTO and the tiller drive boxes. Did a lot of shopping and the TSC is as good as most unless you move up into industrial units and obviously they are built for industrial usage and are more robust with increased cost. Each mfgr. I viewed, did the bracing a little different but all had chain drive and 6 tynes per hub for a total of 54 HD tynes.
I don't see the need for an industrial and I have been grinding up rock hard black clay with no sign of anything being over worked. I would recommend the gear drive and that is all I have seen for sale around here. Just like back in the early days of hand operated tillers, gear drives is all you had. Then somebody decided to make them cheaper and tried chains....tried the same thing with 3 pts. Guess what.....
Recommended oil is 80W-90 but after having gear problems with light oil on a tractor, I use 85w-140 in all my farm gear boxes that call for gear oil. Course if I lived in Canada I might opt for the former for easier starts and then again I might not. We're not talking about an internal combustion engine oiling requirements here, we're talking about a HD gear box.
On filling consult the owner's manual for"fill and" "full" ports. Again, this is a gearbox which are not designed to be filled to the top. On most, "full" is like one third or forth the height of the chamber and there is usually a little pipe plug at the full level for setting it.
Actually I am looking at the TSC as well. I will end up going with 60". I get HOW I fill with oil. Same process as my rotary mower. Just would be nice for them to tell me I need a gallon so I know how much to buy!
I would agree quality wise since I am not tilling for a living the TSC one will suffice. I do not need to spend double on one that is built more solidly.
I was hopeful to find a used industrial one that was price more along the lines of the TSC or KK new one... but alas around here they still want way more than the new TSC one for used industrial.
   / What is with impliment makers? #4
Take a look at the website for Blain's Farm & Fleet.
Their prices are always great (sales even better), and their shipping is usually cheap.
They usually ship from their warehouse in Janesville Wi.
I have a 60" KK tiller from them, and they beat the pants off every other sellers price!
Their price, right now, on a 60" KK tiller, is $1555 plus shipping, but they do have sales also.
No tax either, on an interstate sale.
I have 4 KK implements, 3 of which came from Blain's (ship dist. 1200 miles).
I live very near a TSC store.
My KK tiller is DEFINITELY better built than the TSC tiller!
Another option is Agri-Supply in North Carolina.
They sell a 60" "tillovator" (has excellent reviews) for $1320 plus shipping (they NEVER do have sales). No tax!
   / What is with impliment makers? #5
Arrgh.
Sorry. Rant over.
Buy a 2 gal. jug of whatever oil meets specs.
You will get an owners manual with the tiller.
Follow the manual instructions.
Keep it simple!
   / What is with impliment makers? #6
.My KK tiller is DEFINITELY better built than the TSC tiller!
Look a little closer. Not WAY better, just different ways to support what needs to be supported if you are talking about the yellow one. Same gear drive and 6 tynes per hub. If you are talking about the red one then yes, like it's setup for a quick hitch and the 3 pt hookup is sturdier, but check the price. It's commercial/Industrial. I looked at KK too and have half a dozen of their products over the years.
   / What is with impliment makers? #7
Who said "WAY better"?
Not me!
I live 6 miles from a TSC store, and see their tillers FREQUENTLY.
   / What is with impliment makers? #8
I would reckon that the manuals should state how much total oil capacity, but how much you MAY need to add could vary due to several factors (not filled for delivery; partially filled; randomly filled- assembly line issue; leaks; changing manufacturing processes etc.). Usually it should be "ensure proper fill level" and refer to how to check/verify.
I'd like to see manufacturers using sight glasses of some sort. But, I dunno, maybe it's really not much of an issue, just like with rotary cutters (where one really only needs to check at the start of a season).
I find that I can look at various brands of something until I'm blue in the face and the real deciding factor, after I've ascertained that I'm on-track with my selections meeting my basic list of requirements, is in hearing what others find from operating the equipment. Most of the time it's nuances, but sometimes there are things that I find that I wouldn't want to live with and equipment that has those negative characteristics are weeded out.
I've got perhaps a bigger challenge in regards to selecting a rototiller. I am not sure whether to shoot for one for my NX, in which case I'd be looking at something in the higher range (industrial), or for my B7800 (smaller scale, so not as heavy duty). On the NX front I'm leaning toward something from EA, as I have had really good luck with EA and EA tends to carry good stuff and to provide excellent support.
But that is my point. The manufacturer knows the capacity of the gear box they created. When you change the oil on your car the manual specifies 5 quarts of oil (or whatever). Now that is not exactly 5. You need to check and it might be 4.75 or 5.2 quarts. But at least you know the approximate quantity to buy at the oil store.
All the manuals I have looked at state to remove the plug and just pour in oil until it is up to the fill level indicator plug. No problem I can do that. Just give me an idea if that should be a gallon of oil, 1 quart, what? That way (a) I know how much to buy and (b) if my fill is +/- >10% off I need to look to see if there is a problem. Is there a leak somewhere or something?
If you have no idea how much oil should be going in you have no way to determine if there is an issue.
Of course if you buy used your millage may vary because you have no idea what the prior owner did or did not do.
   / What is with impliment makers? #10
Well, if the manuals don't have it and it's an issue then look elsewhere. Or, one can look to get into the engineering or tech-writing departments of one of the troubling manufacturers and whip them into shape!:laughing:
Seriously, yes, I get it that this is a vent, but sometimes one has to move on. Contact EA or someone like them and ask them- they carry a few different brands and know each really well.
I've gotten hung up on this kind of thing MANY times, I totally understand. But, it's the world we live in and I've got work to do, work which eventually tells me to just buck up and figure it out.
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
ROADTEC RP-190E-3043 ASPHALT PAVER (A51246)
ROADTEC...
2025 New/Unused Wolverine 72'' Skid Steer Ripper (A51573)
2025 New/Unused...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
