What is this
/ What is this
My 1850 is a Hydraulic brake... I have to flip a lever and let the system pressurize before I can roll it forward or reverse. If you need to move the PT and cannot start it you must hand pump the brake, then release the brake lever (also you must lossens some nut on the pump or direction control at the pump so the oil can flow free).
Flipping the lever kills the hydraulic juice to the wheels (treadle goes inactive).
Now, I am not sure if the treadle is dead but when you apply pressure there is no bogging of the system (I would think it would bog if the treadle remained pressurized).
Anyway... There may be springs in the brakes. I am not sure how the brakes actually work on the PT 1850.
/ What is this #22
Carl,
What you are doing by flipping the lever, is to open a small orifice in the pump to let fluid free flow through the wheel motors and pump. Since the orifice is very small, you should only tow a short distance, or the hydraulic fluid will heat up really fast.
The fluid is actually bypassing the pistons in the pump. The engine should not be running.
Based on what you have said, I believe that your wheel motors are spring activated, and when you are pumping it up, the hydraulic pressure that you just pumped into the accumulator is then used to release the brakes. It would only be logical.
My old 1445 uses a spring loaded pin to engage a notch is a disk , and that is only for a parking brake. I could have used a braking system when my 1445 was rolling backward down a hill with no control.
/ What is this #23
J.J.
Your understanding is my understanding.
Sorry to have been unclear. The brakes in the 1445 are spring on, with hydraulic overpressure to release them. There is a parking brake, which electrically opens a solenoid to dump the pressure and apply the brakes.
The spring applied brakes with hydraulic overpressure are available on a number of wheel motors from several manufacturers. To my knowledge, they are only used on the 1445, 1460, 1845, and the 1850. It was a major reason why I didn't buy the 1430.
I hope I never have to go through this procedure, because it would mean that I have a very, very sick PT:
To move my generation 1445 without engine power,
  1. You have to remove the brake pressure output plug on the brake interlock manifold.
  2. Then connect a hydraulic hand pump and a pressure guage, both user supplied.
  3. Then loosen the tow valve 1- 1.5 turns, turn the ignition key to on, and turn the parking brake to off.
  4. Then pump up the system to 600psi to release the brakes, but you probably want to chock the unit so it doesn't roll as you get to pressure.
  5. You turn the ignition key to off or the parking brake switch to on to stop. (Whereupon you would need to pump up the brakes again, if you wanted to move it farther.)
The 18XX series have the hand pump built in as part of the brake tender. If it were a common need, I would add the pump, and a valved, and plumb the pump in permanently.
All the best,
Peter
J_J said:
Peter,
Are your brakes spring applied or hydraulic applied? I remember reading somewhere, that the brakes were spring loaded, and when stopped the spring applied brakes would keep the hydraulic motor from turning. When there was enough pressure built up in the fwd or reverse mode, part of the hydraulic fluid going to the motor pushes the springs back allowing the motor to turn. I can't remember if this system was used on hydraulic motors from PT, or other manufactures.
Although hydraulic accumulators are used to dampen out pulsations, in some system, I am thinking that the accumulators used on the PT is used for the brake system. Is it true that you can pump up the brakes on certain PT's? If this is true then the hydraulic accumulator is used to store fluid under pressure for the brake system.
If you have the spring applied brakes, and you have to move the PT with engine off, what do you do, pump up the system to get the brakes to release, and of course turn the the free flow valve on the tram?
/ What is this #24
I remember reading this in another post of yours. Your story put the fear of God in me about this sort of accident, which is why I went for the 1445. We have lots of 25-30 degree slopes.
All the best,
Peter
J_J said:
...My old 1445 uses a spring loaded pin to engage a notch is a disk , and that is only for a parking brake. I could have used a braking system when my 1445 was rolling backward down a hill with no control.
/ What is this #25
ponytug said:
J.J.
  1. you have to remove the brake pressure output plug on the brake interlock manifold.
  2. Then connect a hydraulic hand pump with pressure guage, both user supplied.
Peter,
That was a good explanation. Thanks.
Do you happen to have a hydraulic schematic for your 1445 you could send me?
/ What is this #26
Your welcome! I'm always glad to help.
Hydraulic manual:
Boy, I wish I had one. After opening my PT manual, and not finding any schematics, I queried Terry about a hydraulic schematic and an electrical schematic. Both were said to be being rewritten...not that I could get an old one...
All the best,
Peter
/ What is this #27
It is my understanding that the brake system on the slope mowers--the 1845 and 1850 is somewhat different than the system on the 1445 and 1460.
I can be quite definite about the 1845 because I have one. The brakes are NOT integral the the wheel motors--they are external and independent of the operation of the wheel motors. (The brake disks are of course mounted on the axle which comes from the motor). The brake is spring applied. The brake is released by hydraulic pressure which can come either from an hydraulic sytem that is powered by the engine or from hydraulic pressure created by a hand pump--the brake tender. A lever on the brake tender controls the application of hydraulic pressure from the engine powered system. The level is automatically moved to release hydraulic pressure if the engine stops or if hydraulic pressure in the engine powered system goes to zero. Thus there is an automatic safety system that applies the brakes if hydraulic pressure is lost--because the engine stops or a hose bursts.
My understanding--I don't know from personal experience--is that the brake system on the 1445 and 1460 is NOT automatically applied in the event hydraulic pressure is lost. Rather my understanding is that it must be manually activiated. Please correct me if I am wrong.
/ What is this #28
Bob, your understanding of the BrakeTender system as used on the 18** series (and PowerTrac's mining tractors as well) is correct. They are both in essence a "Fail-Safe Spring Apply/Pressure Release"-type system that use heavy springs to apply the brake, and hydraulic pressure to release it.
The 18** series machines use external calipers and discs where the other Red machines (except the 1430) have internal brake componants within the wheel motors. These are commonly used in other mobile hydraulicly driven machinery. These will apply full braking when hyd pressure drops below a set point, but will automatically release when pressure rises above that point. The non-BrakeTender equipped machines have a dash toggle to cut pressure to the brake system independent of the drive system to allow them to "apply" and serve as a parking or emergency brake.
In addition to the larger external brake componants, the BrakeTender can be manually pumped up to release the brakes if a disabled tractor needs to be moved. It also has to have the handle manually moved by the operator if automatically "set" by low pressure (does not have to go to zero) such as if you bog the engine down too much.
Both systems are either "Full On" or "Full Off" in that they can not be modulated as an operating brake. Unlike a "pin" system, however, they can be applied with the machine in motion without damaging anything, although the stop may be fairly abrupt. Neither of these systems will jam or bind-up if the machine is parked on a slope or otherwise under load.
/ What is this #29
I found this on the Internet about brake tender. Check it out and see if any of this applies to the PT's.
singlehand
Check out the data at the bottom of the page. Some good schematics, and pictures.
This is their mailing address.
Mail: P.O. Box 539 Tazewell Industrial Park, Tazewell, VA 24651 Three guesses who else operates from there.
/ What is this #30
singlehand
The parent of Power Trac started out making mining equipment. My understanding is that the brake tender system is a safety system required to meet mining machine saftey regulations.
/ What is this #31
It is a carry over from the mining section. It appears to be a good system. They knew this technology long ago, why isn't it on all PT's? The braking system on my 1445 was totally left off. All I have is the parking brake, darn the luck.
/ What is this #32
I suspect cost and the price customers are willing to pay is a major factor in such decisions. If you look at the price of a slope mower --the 1845 for example, ($24,000) compared to the 1445 ($20,000) you can see what the difference in price is for thee items--the brake tender system, a tilting seat, and dual wheels. Of course the 1445 lifts more so the price of the three items is really more than $4000.
/ What is this #33
I'm in the same boat with my 1430. As a matter of fact the parking break is only operating on one side right now. I guess we will have to carry a chain and anchor to through out in an emergency JJ. Or maybe like on those carts we used to build as kids. A big handle to pull that rubs on the tire.lol.
/ What is this #34
All humor aside, maybe we should think about how you could add a brake to the PT. Something like you suggested above might be a start. Or maybe something to grab the slotted disc, but not in a "Lock it Now" mode.
/ What is this #35
What would happen if you stopped all fluid flow to the hydraulic motors? You would have a brake system, right.
How about something like this installed in the forward and reverse lines to the wheel motors. They will pass up to 40 gpm's when a pilot pressure of 100 psi is applied. If you lost all hydraulic pressure, the system comes to a stop. If you take your foot off the treadle, the wheel motors stop.
This unit is called a pilot operated flow control valve. Static state is normally closed.
Surplus Center Item Detail
/ What is this #36
The very fact that PTs pretty much come to a stop when the treadle is in "neutral" atests to the point you make JJ.
One reason this does not constitute a real "emergency brake" however is it depends on everything upstream to remain intact and for there to be practically no internal leakage within the wheel motors. The valve you mention would address the issue of a hose or componant upstream from the valve failing, but there is more internal leakage in hyd motors, especially after much usage, than you might think. You would still slow down to 1/2 or 1 MPH, but it would not stop or hold you on a slope.
User solutions?
One would be to replace the OEM wheel motors with models that have internal wet-disc brakes. Most likely no hyd changes would be needed, but the motors will be longer and thus may need to be spaced out from the tractor body. This may be more of an issue in the rear tub than up front, however. This would give more stability at the expense of greater overall width, but no additional strain on wheel bearings as the off-set would be the same. Could just do one set if motors were otherwise identical.
Another possible solution would be to add one or two pairs of external brake discs and "spring apply/pressure release" calipers like the 18** series use and set up like the other wet-disc machines but without the hand pump. Even if done only to one end, such as the rear, you would have a fail-safe emergency & parking brake that could be used while in motion.
None of these options are inexpensive, but are certainly feasable. If PT at least offered such as a factory option, would be much more reasonable cost.
Just my $.02
BTW, JJ, I have a couple extra brake parts from when I changed out my wheel motors that "may" fit or be adaptable to your older 1445 if interested.
/ What is this #37
When I first got my 425, or at least not long after, I got my pt on a small slope not real steep. While on the slope the pt would coast down so I put both feet on the front wheels to see if I could stop it from coasting. I could slow the coasting down almost to a complete stop. I had in mind the scrubber brakes at that time but never did anything to see if it would really work or not. My land is not that steep so it wasn't a priority. The scrubber or rub brakes would probably be hard on the tires. If you could fix a round drum that would fasten on the the rim and stick out far enough that you could put some kind of caliper on it you might be able to fix a braking system like that, just something that I have been kicking around in my head for quiet a long time now. One of these days someone is going to do it, but these days seems like I just barely get done the things that I have to [haven't been feeling well lately].
/ What is this #38
Sorry to hear you are not feeling chipper Toy.....hope the Doc or someone figures it out and you get back up to speed real soon. Could be those mid-winter blues.....maybe some sunlight....artificial or genuine.
In the mean time, don't let your 425 run you over!
Good Luck !!
/ What is this #39
Rip,
Please send me a PM or email about the brakes that you have. With pictures if you have them. I had thought about the disk brakes like on go-carts.
The slotted disk that I now have on the 1445 could be replaced with a solid disk, and a hydraulic or electric caliper
Generac QT02724 Anax Generator (A61572)
Generac QT02724...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
6R BEDDER (A63291)
6R BEDDER (A63291)
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
