What is this Pin Called and Why is it Loose?
   / What is this Pin Called and Why is it Loose?
Well, I believe I can now put this issue to rest. I happened to actually read the accompanying owners manual that came with the cutter this morning (imagine that!). It plainly says on page 25-2 in an important note: Recommended hitch pin size is 28mm (1 1/8 inches) diameter and at least 7 inches between the pin shoulder and the spring locking pin hole.
So, they delivered the tractor and the cutter with the incorrect pin size and told me it was the correct pin! I will be contacting them this morning. They owe me the correct pin.
   / What is this Pin Called and Why is it Loose? #22
1-1/8” diameter sounds right on a big heavy implement.
true the 3/4” will work but why skimp & risk it breaking.
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
2006 Ford F-450 4x4 Service Truck (A56858)
2006 Ford F-450...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
LOT OF AIR GUNS & HAND TOOLS (A58374)
LOT OF AIR GUNS &...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
